Modding a DVD-V/A SACD player
Nice work Larry! Any thoughts to "beefing up" the wiring in the power supply and other key wiring?Carl
Larry?:eek:
Other than adding a real power cord to replace the piece of thread they included with the unit, I think I will just wait and see how far these mods get me.Adding the new dedicated supply with sufficient guage wiring should be enough.Testing
Testing
Testing -
Great,what model of CDP and what will the 2604 be replacing?You should post some pics.
It's just a Yamaha CDC-645 I picked up for $20. It came with some JRC 2068 opamps. I started the project, but I didn't have all the parts yet, so I'm still running the old opamps. I removed the mute circuit and soldered in the IC sockets. I tried removing a lpf between the DAC and the opamps, but that was a bad idea and made it noisey, so I've ordered some parts to fix that.
I found this excellent desoldering tool at work. It works so well the opamps literally just fell out, and were in such good shape that they still were usable in the sockets until the BB amps get here. I highly recommend one of these to anyone who is removing components from a pcb.
I don't think its wise to remove the LPF but you may want to upgrade any output coupling capacitors as they are most likely cheap electrolytics.Depending on the DAC used you may even be able to eliminate them entirely as long as DC offset is very low.The 2604 has very low offset so you may even be able to eliminate the output caps entirely.It will depend on the type of DAC the Yammy uses and if it outputs DC.. I tried removing a lpf between the DAC and the opamps, but that was a bad idea and made it noisey, so I've ordered some parts to fix that.Testing
Testing
Testing -
Larry?:eek:
Sorry, too much Polkfest on the brain.:o
That desoldering tool looks like it's as large as a toilet plunger:eek:Carl -
Lol, yeah it looks huge in the pic for some reason, it's not much larger than a standard soldering iron.
I just discovered my rail voltage is +/-7V to the opamps. Is this going to pose a problem when I put in the Burr Browns? I've ordered some OPA2134's. Does anyone know if sound quality will suffer from such low rail voltage? -
The only coupling caps in the analog signal path are between the LPF and the first opamp. I have some poly caps ordered to go in this spot. I wired the last opamp's outputs directly to the RCA jacks. -
The 2134 will be fine with the +-7 volts.It can operate on as little as +-2.5 volts.
I just discovered my rail voltage is +/-7V to the opamps. Is this going to pose a problem when I put in the Burr Browns? I've ordered some OPA2134's. Does anyone know if sound quality will suffer from such low rail voltage?Testing
Testing
Testing -
It is most likely there to block DC from the output of the DAC.The only coupling caps in the analog signal path are between the LPF and the first opamp.
Good plan.I have some poly caps ordered to go in this spot
I s there a 100 ohm or similar value resistor between the opamps output and the RCA's?It should have one.I wired the last opamp's outputs directly to the RCA jacks.Testing
Testing
Testing -
Good plan. I s there a 100 ohm or similar value resistor between the opamps output and the RCA's?It should have one.
I don't have a resistor in there. Would the resistor be there to prevent feedback or distortion? I have some 180 ohm metal film resistors I could put in there, it seems to be working fine, but I can throw them in when the rest of my parts arrive. -
The resistor is there to isolate the opamp from any capacitance in the output interconect cable that may cause instability.
180 ohms is just fine.Testing
Testing
Testing -
I completed the project and it sounds much better. The CD player always seemed to have a really forward and aggressive sound. Now it is much more laid back and the treble is more pleasant. The soundstage seems narrower though. I'm going to experiement with different opamps. Is pure satisfaction with sound even acheivable?
:D -
I have an APL-DV-563A mod:
http://www.aplhifi.com/Pioneer563a.html
I thought I linked in here the information of what Alex Peychev did to it. It is an obsolete mod since as you know, DV-563A has been OOP for a couple years. Mine is still going strong and hasn't had the urge to replace since then.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
I made some progress over the weekend and partially completed the two op amp boards.I still need to install the components that form the low pass filters.I used chip sockets which will allow for easy swapping and comparison of different op amps in the future.
The blank double sided copper board shown in the pic will be mounted underneath the new boards.This should help shield them from RF produced by the digital circuits on the main board directly below.
Can't do much more until I recieve my parts order from Digi Key.:(
I like the fact you are using a socket for the op amps. I dabble in electronics a bit, and was curious... do manufactures (Sony for instance;))use sockets for their op amps, or is that just genius on your part:)
Thanks BenPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Maybe for a few minutes.:DIs pure satisfaction with sound even acheivable?
:D
polkatese, the DV 563 with a properly modded analog stage such as you have ,can really be a decent sounding player.;)Im certainly pleased with the first unit I did.(still have some work to do on the second unit).Testing
Testing
Testing -
usually manufactuers do not use sockets because a solder connection is better and more reliable.Also many of the units produced in the last few years use surface mount parts which make it difficult to change IC's unless you have the right soldering equipment.... do manufactures (Sony for instance;))use sockets for their op amps,
He he definately not genius:D just for convience.I used the gold plated machine pin type as they make better contact with the chips leads.is that just genius on your part:)Testing
Testing
Testing -
usually manufactuers do not use sockets because a solder connection is better and more reliable.Also many of the units produced in the last few years use surface mount parts which make it difficult to change IC's unless you have the right soldering equipment.He he definately not genius:D just for convience.I used the gold plated machine pin type as they make better contact with the chips leads.
I like the swap ability:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
yep. can't complain. It's actually make me appreciated my LSi15 even more since it let me hear micro details..:)I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
I finally have the second unit up and running.I have so far only tried redbook CD's using the main outputs.The LM 4562 opamp sounds smooth and creamy but in direct comparison to the first unit the sound stage while sounding big and open it's as though it has been moved back several feet.
Im not sure I like this mid hall perspective
Also the discrete output stage in the first unit has supierior bass extension and drive.So far the differences in SQ are greater than I was expecting.Next up will be comparisons of both 2 ch and multi chan DVD-A and SACDs. Testing
Testing
Testing -
For those of us not paying attention - what op-amps are you comparing to the 4562? Do you like the 4562 or the other better? I have not modded my DSP board yet in the NAD (its next to go) - still deciding what opamps to go with. (would have to match to the LM4562 in my output stage)
As detailed in post #1 the first player has a OPA2604 that has it's output buffered by a discrete high current opamp.The second player has an LM4562 to drive the outputs(so no discrete op amp).For comparison I also plan at some point to replace the LM4562 with a OPA 2134.For those of us not paying attention - what op-amps are you comparing to the 4562?Testing
Testing
Testing -
Take a look at the OPA 2228 as well. I tried both in my phonostage and the 2228 is more open and present. The 2134 sounded a little veiled in comparison. I'm thinking of "rolling" the 2134's in my cd player with 2228 now.
Having had lots of time to do comparisons between the two modded players I still have a strong preference for the first unit.While the mods on the second unit certainly improved it sonically ,everytime I put it in my system I was anxious to return to the first unit.The comparison proved in my mine atleast that the analog output stages in digital components have a large effect on SQ.The discrete class A op amp in the first unit beat the highly touted IC op amp in the ares of bass detail and depth,more detailed mids and better dynamics.Testing
Testing
Testing
