Placement of Center Channel with a Flat TV?
dvran
dvran Posts: 280
I know I'm not the only one with this problem, but does anyone have any inputs on how I can place my center channel speaker under or over my flat panel TV? :confused:
I have a Csi40 and the 40" Samsung LCD TV. Right now, I have the TV on top of the center channel speaker. It seems to work well, but sort of looks ghetto. I wondered if any of you have incorporated shelves or even elevated the TV a bit and placed the center channel behind the TV?
Thanks...
~Dan
Projector: Epson 705HD on 106" DaLite
TV: Samsung 50" Plasma PN50B550
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
Sub: Velodyne Minivee 10
PS3 and Xbox
Post edited by dvran on
  • AndyGwis
    AndyGwis Posts: 3,655
    edited October 2007
    I have TV stand with three shelfs. First level is my receiver and separate amp, second level my HD-DVD player, third level my center speaker.
    Lot of different way to go about it, but I think this way is best. Some move their TV to the back of the stand and put the center speaker in front if it. Guess that works okay if the speaker is shorter than the TV's stand, but still looks less than perfect.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • jwhitakr
    jwhitakr Posts: 568
    edited October 2007
    If you don't want to replace your TV stand, another option is to get a shelf / stand that sits on top of your TV. That's what I did, and am happy so far with it.
    I used the Omnimount CCH1 - here is a link to the mfr. website.
    I should take pics sometime and post them in the system showcase, just haven't gotten around to doing it yet ...
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
  • dvran
    dvran Posts: 280
    edited October 2007
    Thats for a big screen TV, where the brackets have a spot to rest. There really isn't anything on the market for these new LCDs or Plasmas that sit on stands.
    ~dan:rolleyes:
    ~Dan
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    PS3 and Xbox
  • PerfectCr
    PerfectCr Posts: 2
    edited October 2007
    dvran wrote: »
    ~dan:rolleyes:
    I just posted a similar question in another thread here. That product would work if the "legs" extended down 2 feet so they could rest on the same surface as the TV. Perhaps one could find a way to extend the legs via some kind of workaround?
  • Early B.
    Early B. Posts: 7,900
    edited October 2007
    dvran wrote: »
    Don't worry -- you'll grow accustomed to the ghetto look. I have mine the same way.
    "God grooves with tubes."
  • zx_toth
    zx_toth Posts: 417
    edited October 2007
    Early B. wrote: »
    Don't worry -- you'll grow accustomed to the ghetto look. .
    LOL ...
    Dvran: Could you post some pictures? I can envision your tv on top of the center speaker but dont understand what the center speaker itself is on ...
    BDI Furniture has some interesting solutions. Mostly being able to hide your center channel in the cabinet immediately below your TV. Check them out, link below. If you post a pic it may be a bit more helpful for us ... at least us guys who need pictures to stimulate us, while women will do with romance novels and words :D
    http://www.bdiusa.com/avfurniture/index.shtml
    Zsolt
  • jamison
    jamison Posts: 35
    edited October 2007
    Early B. wrote: »
    Agreed, mine isn't quite so ghetto, but I do have the speakers just sitting in front of the TV.
    J
    Jamison White
  • jfeinman
    jfeinman Posts: 29
    edited October 2007
    if you have a wall behind your TV, get a simple shelf or do something with angle brackets.
    _______________________
    Fronts: Polk SDA-2s
    Center: Polk CSi-3
    Surrounds: Polk RTi6s
    Surround Backs: Polk RTi4s
    Sub: Velodyne DPS-12
    Receiver: Onkyo TX-SR703 (THX Select2)
    DVD: Harman Kardon HK-DVD22
    Xbox 360
    TV: Panasonic 42" PX-75U Plasma
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited October 2007
    Look at parts express...they have some solutions for you. check out speaker brackets and stuff there.
  • AndyGwis
    edited October 2007
    Here's a pic of my setup. I already know it's a little blurry, crooked, etc. What can I say, I suck at taking pictures.
  • phipiper10
    phipiper10 Posts: 961
    edited October 2007
    I used one of those shelves with the feet on top of my Samsung DLP. The TV started to sag just the tiniest bit from the weight...that was enough for me to say no center channel on top of the tv. I have the CS400i - much like you. It's big and heavy plus from that Angle I'd want to angle it down to the listening are which is a risky proposition in itself.
    As a solution I removed the shelves on my TV stand and built my own shelf at the right height and have it angled up towards the listening position. It works pretty well for me.
    Good luck, I struggled with a solution I could live with for quite a while and my first solution wasn't the one I stuck with.
    You'll figure it out.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • engtaz
    engtaz Posts: 7,672
    edited October 2007
    AndyGwis very nice and clean setup. Sweet
    engtaz
    engtaz
  • kiheiman
    kiheiman Posts: 4
    edited January 2008
    I too am struggling as to where I should locate my center channel speaker (RM6700 system). I currently have it located on top on my stand in front of the TV (see attached picture). This seems to work OK, but I would like to get a bigger center channel speaker, thus the current location would not work. I have seen a number of posts about the Omni mount system. but it seems to have a number of problems. It seems that some people have had a problem where the mount actually fell off the TV.
    Has anyone tried the Vantage Point AX2LSB01-B mount with a AX2WL01-B flat plate mount. It is supposed to handle speakers up to 15 pounds. Here is the link for this mount:
    http://shop3.outpost.com/product/4863710?site=sr:SEARCH:MAIN_RSLT_PG
  • tecmo04
    tecmo04 Posts: 421
    edited January 2008
    Although i dont have an lcd anymore i still was faced with a similar issue with my new tv. The shelfs on my tv stand were to small to fit my cs400. So i went to Home Depot, bought some brackets and screws.
    Found some left over wood sitting around and painted it black. Cut out a notch in the back for the wire to run through. From the front its completely invisible (see pics in signature too).
    Moral of the story, DIY is cheaper, easier, and you can customize everything!
    My 2cents...
