MP3 player through my system
1235»
  • Yashu
    Yashu Posts: 772
    edited October 2007
    Flac is definately the way to go... You are sure to get lossless without a doubt.
    You CAN use raw wav files... actually... many many PC audiophiles rip a CD as one long WAV with a .cue sheet for tracks... and then they use a player that can play by cue sheets.
    In windows you can set a folder or a drive to be compressed by the operating system. This would give you the FLAC-like compression but allow you to keep the raw wavs, if that is what you want.
    I prefer my tracks to be devided so I can choose from within windows explorer... and flac will give you completely lossess and a good saving of space. Both winamp and foobar support flac and I am sure the squeezebox does too.
  • phipiper10
    phipiper10 Posts: 961
    edited October 2007
    Whats your drive offset?????? ;)
    Jitter correction? Indian -what??? :)
    Even for audiophiles a bit perfect copy isn't necessary for it to sound exactly like the original - if your offset isn't right you'll enjoy the sounds just the same - for the record I do have my version of EAC set up properly!
    I've mentioned these sites before but I'll do so again here. They are great resources for lossless, free, live music.
    etree.org
    http://www.shnflac.net/
    GO SEE LIVE MUSIC -(JAMBASE.COM)
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited October 2007
    Ok. here s a wrench in the works. What do you use for Mac Books to get something similar ro EAC/Flac?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Gaara
    Gaara Posts: 2,415
    edited October 2007
    Apple Lossless would be your best bet.
  • wingnut4772
    edited October 2007
    Gaara wrote: »
    Really? That's the closest equivalent for Mac?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Gaara
    Gaara Posts: 2,415
    edited October 2007
    Ok now I am confused, why is a Mac Book different then any other computer? I know Macs are difficult to use with some programs so I inferred by your ? that they couldn't run EAC and FLAC, which is why I said Apple Lossless.
    No matter which format you choose (Apple Lossless, FLAC, or WMP Lossless
    ) there should be no difference in sound quality as they are all lossless compression techniques.
  • wingnut4772
    edited October 2007
    It's my understanding that the EAC program will not run on a Mac.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Gaara
    Gaara Posts: 2,415
    edited October 2007
    Ok that explains the confusion, I was mistakingly under the impression that EAC works on a Mac but the FLAC encoder did not.
    Sorry I can't help, never used a Mac before.
  • wingnut4772
    edited October 2007
    Well the Apple lossless sounds terrific with my DAC1 so I suppose I will just suffer.:p
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
    heiney9 Posts: 25,498
    edited October 2007
    Gaara wrote: »
    Not nec true. Some feel there is an audible difference between the 3. I have the most experience with FLAC and it has produced superb results. Apple Lossless and WMP Lossless aren't always a bit for bit copy.
    Again, can one hear a difference, maybe maybe not. Cetainly if you don't have support for FLAC then you may have no other option. Strcictly speaking with the squeezbox, it's compatible with all 3 but I would use FLAC.
  • Gaara
    Gaara Posts: 2,415
    edited October 2007
    I agree which is why I said that "there should be no difference...". If they are all lossless then by definition there is no difference between them, they should all be bit perfect copies of the original and therefore identical to each other.
    This of course may not be the case in the real world.
