help please
sageleo
sageleo Posts: 170
My current set up is monitor 40's biwired run off of an h/k avr 245. I just got a pair of rt20p's and I'm using the same biwire but when I hooked up the speakers my avr starts blinking protect and shuts off. Have I done something wrong? If so how do I fix it?
thanks
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
  • Face
    Face Posts: 14,340
    edited September 2007
    Check the new speakers with a Ohm meter.
  • beardog03
    beardog03 Posts: 5,550
    RT 2000 P`s ?
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • sageleo
    sageleo Posts: 170
    hmmm... not really sure what u mean ohm meter? my h/k might not be suitable for the speakers?
  • sageleo
    sageleo Posts: 170
    nope rt20p
  • sageleo
    sageleo Posts: 170
    I will also say that it only seems to go to protect mode at higher volumes. Is it bad for the speakers or reciever if I use them just not at higher volume?
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Hook them up one side at a time to isolate the short/load issue.
  • sageleo
    sageleo Posts: 170
    I tried that and it still goes into protect, now the biwire is diy biwire could that be an issue?
  • Dennis Gardner
    I still say short/load issue. You may need to check out the wiring diagram.http://www.polkaudio.com/forums/showthread.php?t=38755
  • sageleo
    sageleo Posts: 170
    dennis thank you for the link. I'm not really sure how to read the diagram tho, or what its supposed to tell me, when u say short/load what do u mean?
  • Dennis Gardner
    Your HK only goes into protect when it "sees" trouble in the signal path. You new speakers may have speaker wire, crossover, internal speaker wiring, or internal amp (since they are powered) issues.
    I would run them without the biwire to see if that makes a difference. + or - switched inside of a speaker at the back of the terminals may be seen by your AVR as a short. Just guessing......
  • sageleo
    sageleo Posts: 170
    ok I think I'm followin you. Does the fact that it only goes into protect when at higher volumes matter at all?
  • Dennis Gardner
    I'm not too familiar with the powered section of the RT20p, as how the inputs work, but biwiring into high level inputs for the subs might be your issue.
    Are there 3 sets of speaker connections for high, mids and subs or just 2?
  • sageleo
    sageleo Posts: 170
    there are 2 sets of speaker terminals, they are connected with brass jumpers. there is also line level in and out. I have it connected as follows. speaker wire into the top terminal w/jumpers removed, and sub hooked up from sub out on receiver to line level in on one speaker then line level out on same speaker to line level in on other speaker. I didn't get a manual with speakers, I work for a moving company and got them as a tip today.:o
  • Dennis Gardner
    I bet your biwire on the bottom pair is in conflict with the line level sub input. This is a common issue with the LSi25 speaker. The bottom speaker jacks aren't tied to the mids, they are actually the high level inputs to your sub amps. This could be your issue...........simply disconnect from the bottom and run only into the top pair, if using the line level inputs too.
  • sageleo
    sageleo Posts: 170
    yup thats how I have them, just plugged in on the top set, but it said to remove jumpers if using line level. sorry if I worded it wrong in last post.
  • Dennis Gardner
    Then you aren't biwiring?
  • sageleo
    sageleo Posts: 170
    correct, my old speakers monitor 40's I had biwired, and the plugs at speaker end of the wire allowed for the 2nd set of wire to be plugged into them. I dont know if that makes sense or not.
  • Dennis Gardner
    I get it............it still sounds to me like the speakers may have some crossover issues that make the receiver see too difficult of a load to drive at volume. HKs have nice amp sections, but they still have limits.
    What happens when you hook them up using the high level inputs?
  • sageleo
    sageleo Posts: 170
    High level for the sub as opposed to line level?
  • Face
    Face Posts: 14,340
    That receiver should have no problem with a small 8 ohm speaker.
  • Dennis Gardner
    sageleo wrote: »
    Yep, this might change the load for the receiver. Run them set to large with no sub in your OSD.
    This isn't optimum for movies by any stretch, simply a load change test.
  • sageleo
    sageleo Posts: 170
    I wouldn't say they are small... way bigger then my old monitor 40's
  • sageleo
    sageleo Posts: 170
    so hook up my other set of wires to high level, unplug the sub cable and change speakers to large and sub to off?
  • Dennis Gardner
    Yep...just trying to resolve your receiver shutdown issue. If that works, then the load change caused by the sub amps resistance may indicate that you have issues in the top end of your speakers in the crossover.
  • sageleo
    sageleo Posts: 170
    Dennis, by god I think you've got it. I was able to turn it up to -15 db and still didnt "protect". When using line level could only go to about -28 db. I thank you for all of your time and help you gave me. Do you know why it doesn't work with sub pre out w/o shutting off? anywho thanks so very much.
  • Dennis Gardner
    I think that some of the old crossover components may be going south. They aren't really that old, but if the values have changed, it may be your issue.
  • Dennis Gardner
    I would definately contact Polk Customer Service and talk with them about the issue. They may have you send in parts, or can help with measurements in self testing. They are great to work with!
  • sageleo
    sageleo Posts: 170
    alright I will contact them, and see what they say thanks again have a good one.
