Toshiba HD-XA1 HD-DVD player
Netflix is worthwhile for HD-DVD adopters. They have great selection, although new releases on HD-DVD are difficult to get quickly.
I doubt you would hear much of a difference if you mix-match cables. Get a pair of sidewinder AQs and be done.
The HD-XA1 is a pretty awesome player / computer. I just recently took the time to properly set up it's bass management system. Do that before you start using the analog outs to make sure things are correct.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Thanks for the info guys. My setup is in no way high-end, so I think any decent ICs should do the trick. I'll probably do a few searches on eBay and check the usual suspects (Monoprice, Signal Cable, etc.) as well. The AQ Sidewinders are a bit more money than I was looking to spend ... will see if I can find a good deal on a used set.
I have read that after connecting the 5.1 analogs, there is quite a bit of config needed in order to get the bass output set up correctly ... something about the analog output lowering the bass signal by -10dB versus using a digital connection. I will make sure to use the bass management system to calibrate the low end after I get it hooked up. Thanks for the heads up!My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd -
I got my sidewinders for $22.50 a pair when Best Buy / Magnolia was closing out their stock. I guess at full price they are a little pricier than basic cables.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
