Well what started as a $300 .....
CRUNCH
christmas gift ( sony system from walmart) turned into "honey, if you dont mind i`ll add a little money and upgrade just a bit". 1500 later i now have onk 600, polk rm6700 and the 404;). i plan to install tomarrow. btw i have lurked on the board for 2 weeks now and read past topics on cables and wire. i was at home depot and was looking at the 14 ga when i saw some green. not much but just a little as if it was a line. closer inspection on the 250ft spool stickers just below- 2 cond 14 ga. 120 volts- was the following....marker 2 green threads. could this be the culprit of the "hd turns green'
Post edited by CRUNCH on
Greetings !
All wire has someway of distinguishing + from -
sometimes it's writing on the insulation or a ribbed surface (as opposed to flat or shiny for the other,sometimes one is silver in color/the other copper colored)
and sometimes it's just a piece of colored thread (red/green etc.)
It really doesn't matter what side you use for + or - just make sure you keep it consistent at amp and speaker ends
(Green thread at + amp/receiver out to + speaker in)
Hope this helps ! and "Welcome" to the forum - Stick around-
many knowledgable and friendly (and Effin' funny comedians)
here !
Ed (Dr. Spec)-Forget SVS- HE is the Bass authority
Russman-funny 'effer and very knowledgable
Troy-ScottVamp-Mantis-Ganzo-Ron-P (wish I had a 1/4 of his knowledge of tools and building/construction and the time to get to Disney 5 days a week:supermad: ) sorry to the ones I did not list-many others!
Have fun,Enjoy...Your upgrades have just begun
CHEERS ! jefffArt as expression-Not as market campaigns-Will still capture our imaginations. -
crunch, you are on the road now, welcome to the forum. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces. -
if the coper is turning grey or black that is a bad thing. i have used the very cheap stuff when i first started 10 years ago it is good but it crodes in 2-3 years. it will still work but not as good. in a year you might want to upgrade to a good cabble not monster cabble but sothing like it thet is oxygen free. monster is overpriced. look at maybe ar or a brand like it. just as good but much cheaper.
and the input. i must say this ht stuff has been fun so far. what can we do, when their are no t-rex`s around to spear !:D
