Sub at or around $150
dipiazza
dipiazza Posts: 363
Hey all,
Im looking to build a friend a HT setup on the cheap. I will probably use hte R300 and R150's from frys for the mains since they are on crazy sale. But i need a sub. Id like to keep it around $150. So far i have heard of the Velo VX-10 and Athena ps-4000 something. Any other ideas for such a low price ? Thanks!
-Jake
Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
Post edited by dipiazza on
  • ilikesound
    ilikesound Posts: 355
    edited September 2007
    trick question?
    lol, just teasing.
    the only and i mean ONLY sub i've ever heard that is even remotely worth spending that much (or little, depending on monetary situation) would be any sony 12'' ported subwoofer designed for home entertainment. While not that accurate, they sure do put out some power (for a measly 120 bucks, therearound)
    that's the only thing i know of that may be remotely in your price range worth spending that kind of money on..AND you will want to upgrade after that too, so might as well just save some money on a decent sub.
    maybe a car oriented sub?? it would be a good experiment, ive been looking at doing the same thing, just to see...
    At Home:
    Panasonic 42'' TC-L42U12 LCD
    Pioneer VSX-80TXV
    Toshiba HD-XA2
    Sony PS3 - psn "metalguitars"
    Xbox 360 - gamertag "giggidygiggidy"
    Panamax 4300EX
    Polk RTi8's
    Polk CSi3's
    Polk FXi3's. (x2)
    Martin Logan Dynamo (x2)
    Audioquest interconnects and wires.
    Away From Home:
    JVC HDR-50
    stock system in new car for now:(
  • Willow
    Willow Posts: 11,297
    My parents have the Athena, it does a decent job. NOw I have ot done testing with it , but from what I have been able to tell it does the job, what more can you ask for in that price range.
  • wingnut4772
    wingnut4772 Posts: 7,519
    I don't think I have ever seen a Sony sub recommendation before..:p
    .but then again I have not heard one either. I would kick my budget up a notch and get a used something else. The sub is a pretty important HT element so you don't want to go too cheap.
    Velodyne
    Athena
    Etc.....
    If you are really strapped the Sonys are pretty inexpensive though.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • AndyGwis
    AndyGwis Posts: 3,655
    I have a DefTech ProSub 80 in my bedroom. I think used ones go for around $200 or so. I would check your local Craigslist for used DefTech subs. They may not be the end-all be-all musically, but even this little 8" BUMPS. It goes low, hits hard, and is extremely impressive for its size and price.
    This is due to its 250 watt amp, I supposed.
    Go used. $150 - $200 won't get you anything worthwhile that's new. Hell, even the PSW10 has a sticker of $200, although Polk wisely decided to just start giving them away. Comparing the new PSW10 to my used DefTech ProSub 80 isn't even funny/fair.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • AndyGwis
  • jwhitakr
    jwhitakr Posts: 568
    I don't have any specific recommendations for subwoofers, but I would second the vote to go used instead of buying new. I recently purchased a used subwoofer and couldn't be happier with it. With the money you save by going used, you can get a whole lot more bang for your buck.
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
  • dipiazza
    dipiazza Posts: 363
    i would have no problems buying used. whats good for under 200 used?
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    2CH Setup
    Headphones
    Other Stuff in Use
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited October 2007
    I have a Yamaha YST-SW010 sub 50 watts rms 100 watts max if your interested brand new only been out of the box for 8 minutes. ill take it for 90 bucks
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • MSALLA
    MSALLA Posts: 1,602
    edited October 2007
    I may still have a polk PSW303 in my closet. If the room is not to big, it will do a fine job. PM me.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • ViperZ
    ViperZ Posts: 2,046
    edited October 2007
    Sony SA-WX700. Dual-10", 250W RMS, sealed enclosure. Amplifier circuit designed and built by B&O (Bang & Olufsen).
    JBL E250 or newer PB12 - ported 12" for home theater, 250W RMS.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • kingtut
    kingtut Posts: 813
    edited October 2007
    I listened to the Velo VX10. I was not that impressed. It was decent, but it was sounded somewhat bloated. If you can find the old version (not the current version) of the Parts Express 10" nick-named "tiny mighty", it's pretty good for the $. I have one and used it for my bedroom HT. I believe it was $200 new, but you can find it used for around $100, once in a while, on HT Forum.
  • dipiazza
    dipiazza Posts: 363
    edited October 2007
    Thanks for the suggestions guys. I was able to convince my friend to spend a little more and i found a SVS PC local for $350. Good deal id say!
    -Jake
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    2CH Setup
    Headphones
    Other Stuff in Use
  • MSALLA
    MSALLA Posts: 1,602
    edited October 2007
    So what came of all this? Did he get the SVS for 350.00?
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • aaharvel
    aaharvel Posts: 4,489
    edited October 2007
    sounds like a good deal on the SVS.
    To anyone else reading this for advice on a budget sub - stay away from the vx10 - at any price.
    If you can an older model CHT series on closeout, that's the option I would take for two bills.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • dipiazza
    dipiazza Posts: 363
    edited October 2007
    Yea i ended up getting the original SVS PC for 350 local. Its working great.
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    2CH Setup
    Headphones
    Other Stuff in Use
  • jeffitz1
    jeffitz1 Posts: 4
    edited October 2007
    Acoustech makes great subs . .but they are spendy.
  • bdjou
    bdjou Posts: 1
    edited October 2007
    I'm considering the bic h100 subwoofer as well. Anyone here knows how it compares to the JBL venue sub12? They are both in the $240 or so price range.
