Rope Caulk For Polk Drivers
ka7niq
ka7niq Posts: 577
edited September 2007 in DIY, Mods & Tweaks
Anyone have any experience with rope caulking the Polk driver baskets ?
I have used it on Horns with mixed results, and on conventional drivers with the same results.
Sometimes it worked, but I have also removed it from some drivers.
I was Thinking about doing my MW 6511 drivers :)
Post edited by ka7niq on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    I have never considered it as basket treatment, I use Dynamat type resonant mat for baskets. I have used the rope between driver and cabs before with good results in sealed boxes.
  • ka7niq
    ka7niq Posts: 577
    In my Horn days, it was quite common to rope caulk a Horn, even a compression driver.
    Driver baskets ring, especially a stamped one.
    Vibration from the basket can go into the cone/surround.
    The NICE thing about the rope caulk is it can easily be removed IF ya don't like it.
    F1nut Posts: 51,776
    Dynamat works much better as it is designed for purposes such as that.
  • madmax
    madmax Posts: 12,434
    ka7niq wrote: »
    Naw, use dynamat. Its cheap enough.
    Vinyl, the final frontier...
  • ka7niq
    ka7niq Posts: 577
    I have heard of Dynamat, never tried it.
    I will chack it out.
  • avguytx
    avguytx Posts: 1,628
    The peel and stick aluminum backed (Dynamat Extreme I think) type is the easiest and best to work with. No heat gun required to activate the glue...like the Dynamat "Original". Man, I've scorched some hands on that stuff thru the years!
    You can get the 10" X 10" squares at a street price of $20 to $25 at BB or CC typically. That should be enough to cover them as it doesn't take having to cover them completely for good results.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
