Speaker Calibration
nellis8166
nellis8166 Posts: 292
I know this subject had been beat to death and I apologize for the redudancy.
I want to properly calibrate my rig today. Do you need both a test disc and ratshack meter???
Can I get it done properly with just a disc???
Where can I pick one of these discs and which one is the best???
Most of the threads I have read says this makes a huge difference.
Appreciate any input and suggestions.
Regards,
Nat
RTi10
CSi5
RTi28
SVS PB12-ISD2
Denon 2106(pre/pro)
Adcom 5503(200x3)
Audioquest Diamondback ICS
Kimber Kable 8tc biwire(mains and center)
"Don't let your silly dreams fall in between the crack of the bed and the wall."
-J. James
Post edited by nellis8166 on
  • jgido759
    jgido759 Posts: 572
    edited February 2003
    Yes, you need BOTH the disc & the Rat Shack SPL Meter. This will insure an acurate balance between ALL the speaker levels so they are equal. I use the Sound & Vision Tune Up disc which can be purchased at just about any Best Buy for about $15.00.
    Oh, you hate your job? Why didn't you say so? There's a support
    group for that. It's called EVERYBODY, and they meet at the bar.
    -Drew Carey
    There is a very fine line between "hobby" and "mental illness."
    -Unknown
    My DVD Collection
  • mantis
    mantis Posts: 17,329
    using a test disc is the best way to calibrate your system for DVD playback.It tests all speaker levels from the player instead of the receiver.
    All digital receivers of today have built in test tone generators,this is also great way to calibrate.But testing from the DVD player is best.
    The Radio Shack SPL(sound Pressure Meter)needs to be used.You can do it without,but you'll most likely be off by a couple db here and there.
    Dan
