LSiC dead speaker
jeffbackdoc
hello. 7.1 LSi speakers hooked to denon 5803. just noticed a dead speaker within the center unit. the middle dynamic balance speaker and right speaker work, but the left one is dead. any ideas as to source of problem. speaker unit? serviceable? 5803? wiring? thanx. jeff
Post edited by jeffbackdoc on
Discussed here.
LSiC ProblemMichael
NORTH of 60° -
first things first - welcome to club polk. Pull up a chair and look around. You just may like it here. (then again you may not... )
Now on to the question - Are you sure you have a problem? The reason I ask is listed in the following threads from some of the many times people ask about the left speaker working in thier LSiC.
If the left side is not just less volume than the right, what is the problem that you think it is broken?
Let us know and we will help whereever we can.
Sorry, welcome to Club Polk. Enjoy, teach and learn.Michael
NORTH of 60° -
I replaced my Csi40 with the LSiC also..
it took some getting used to, as the CSi40 has alot more sound/volume,
I am now used to it, and am still calibrating the system all the time, because I have a habit of changing things around alot.
I run the rears and the center a litte "hot" and it seems to work wellCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
