Eye protection
Frank Z
So I just got back from the eye doc. After **** around for more than a week I finally figured out what I wasn't getting any better I consented to going to the doc....basically Deb told me I was going. Had a nice piece of steel embedded in the right eye lens above the cornea. It got in there 10 days ago when I was working on a friends Jeep. Even though I had safety glasses on while grinding I still managed to get some metal in the eye.
Good thing I did, and damn foolish for not going sooner. The doc had to use a scoop and a miniature Dremel to get the steel out and I still need to go back in a few days to have the eye checked again. Chances are prety good that there is still some rust in the lens.
I currently have a Bandage Contact Lens on the injured eye and it its feels like I'm looking through a piece of Saran Wrap. I've got steriod drops, pain relief drops, and antibiotic drops to put in to. My eye looks like a Rand McNally Road Atlas. Yeah I get a day off, but that just screws up the rest of my week.
So why should you give a rats **** about my eye? Easy, you shouldn't. In fact you should probably be saying "What an idiot!" I posted this little story so that you folks might learn from my stupid mistake. If you get something in your eye and you aren't 110% positive that you got it out...GO TO THE FREAKIN' DOCTOR!!
I'll be damned if I let this happen again. From now on no work comenses in the Oh Crap! Garage without safety glasses and/or face shields for any and all present.
Gotta go put some drops in...and kick myself in the ****.
Real men don't wear eye protection :P j/k!
Well if you want to be super safe a Welders mask should do the trick!My Home Theater (WIP):
Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
Receiver: Denon AVR-1905
Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
Dual Subs: PSW202, and behind the couch Denon 8"
My showcase link:
Media Room pics -
Good advice; I've had my share of eye accidents, including a battery that exploded while I was looking into the cells to see acid level....I was at a shop and a mechanic that saw what happened grabbed my a$$ and almost drawned me in a water fountain. The doctor later said that if it wasn't for that I would be blind.
Hope you get well soon._________________________________________________
66chevyIISS wrote: »Well if you want to be super safeQUOTE]
...............let someone else do the work !
On another note, I do remember one painful eye situation. I was trying to fix a plastic from around this hand held mirror. So I dabbed on some crazy glue when I pushed the pieces together to hold it snapped into place and shot the Glue in my eye......Holy burning batman ! Went to a hospital they said 4hr wait go to clinic, I went to a clinic they said we can't work on that here go to a hospital. So off to another hostpital. After a couple different drops I was able to open my eye.
Luckily I wear glasses...One time I was desoldering an 50 volt dc motor for the X/Y/Z stage of one of our laser tools....All the wires desoldered perfectly..had 2 other techs helping because the ground strap for the motor was soldered on and needed more then one iron on it because it was acting like a big heat sink ...when all 3 of us got the irons on it it let loose and my left lens of my glasses looked like one big solder splash. Everybody asks me why I dont get contact lenses...I just smile and say they are not for me....The first rule of Fight Club is you don't talk about Fight Club
When you're done bend over & have Deb kick you a few more times!:mad:
Fricken idiot men!! All the common sense of a flea!:mad:
I hope you feel better soon.:)So I just got back from the eye doc. After **** around for more than a week I finally figured out what I wasn't getting any better I consented to going to the doc....basically Deb told me I was going. Had a nice piece of steel embedded in the right eye lens above the cornea. It got in there 10 days ago when I was working on a friends Jeep. Even though I had safety glasses on while grinding I still managed to get some metal in the eye.
Gotta go put some drops in...and kick myself in the ****.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I felt my Oakley's get lifted off my nose more than a few times while weedeating. Money well spent.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
I work in the shipyards and have seen my share
ALWAYS WEAR YOUR PPE (personal protective equipment)...ALWAYS
Glad all is going to be okay
alot of guy`s in the yard had to learn the hard way....some of them will never be okay againCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Correct, when doing anything unsafe always wear eye protection, a hard hat, and an athletic cup
Just got back from my follow up...more grinding. Yippie!
Had a "Rust Ring" from the original piece of steel, but they broke out the Dremel and dug it out. Looks like I might get a 3rd grinding session next week too.......insert whinnie heavy sigh. -
Frank I too did that working on some ones small block heads, but I did it to both eyes. Yes wearing EYE PROTECTION.... I feel your pain.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I did this years ago...laying under the car and drilling directly above my face...with NO eye protection. A hot metal sliver in the eye is not a fun thing. Alas, then I was young and stupid. I am no longer young."Just because youre offended doesnt mean youre right." - Ricky Gervais
