TC620i vs SC60 ceiling speakers
len1jane
len1jane Posts: 5
edited June 2008 in Speakers
What is the difference between the TC620i and SC60 ceiling speakers.
Will they match well as rears with (2) RTI8's fronts and (1) CSI3 center.
Post edited by len1jane on
  • dragon1952
    dragon1952 Posts: 4,907
    edited September 2007
    It looks like the TC620i has gold plated speaker wire terminals and can accept up to 12 ga wire. I believe the SC60's only accept up to 14 ga wire. Also, the frequency response on the TC620i is better.
    TC620i - 35Hz-25kHz, Lower -3dB Limit 50Hz, Upper -3dB Limit 23kHz
    SC60 - 40Hz-20kHz, Lower -3dB Limit 60Hz, Upper -3dB Limit 20kHZ
    They are both voice-matched to the RTi and CSi series so you should be fine. I'd be tempted to go with the SC60's for over $100 less.
  • readonly
    readonly Posts: 12
    edited June 2008
    good to know.
    dragon1952 wrote: »
    F1nut Posts: 51,771
    edited June 2008
    Sure enough.
