TC620i vs SC60 ceiling speakers
What is the difference between the TC620i and SC60 ceiling speakers.
Will they match well as rears with (2) RTI8's fronts and (1) CSI3 center.
Post edited by len1jane on
It looks like the TC620i has gold plated speaker wire terminals and can accept up to 12 ga wire. I believe the SC60's only accept up to 14 ga wire. Also, the frequency response on the TC620i is better.
TC620i - 35Hz-25kHz, Lower -3dB Limit 50Hz, Upper -3dB Limit 23kHz
SC60 - 40Hz-20kHz, Lower -3dB Limit 60Hz, Upper -3dB Limit 20kHZ
They are both voice-matched to the RTi and CSi series so you should be fine. I'd be tempted to go with the SC60's for over $100 less.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
good to know.dragon1952 wrote: »It looks like the TC620i has gold plated speaker wire terminals and can accept up to 12 ga wire. I believe the SC60's only accept up to 14 ga wire. Also, the frequency response on the TC620i is better.
They are both voice-matched to the RTi and CSi series so you should be fine. I'd be tempted to go with the SC60's for over $100 less. -
Sure enough.Political Correctness'.........defined
