MM104 or Boston Proseries 10.5??
phuz
I'm a big Polk fan, but I hold Boston Acoustics in in just about the same light. Each has it's yin and yang.
I'm looking for SQ mostly. Right now I've got a kicker 120.2 amp pusing my current sub, and will be using this amp to push the new sub until I can upgrade to a better amp(probably not anytime soon) - the enclosure that I will use is a JL Vantage sealed enclosure with roughly .60 cu. ft. airspace - this will be inside the cab of my truck almost directly behind the lower lumbar portion of my seat. (as seen here - http://www.jlaudio.com/stealthbox/va_ranger.html )
Which sub would you choose in these circumstances? And why? Thanks!
Post edited by phuz on
Oh come on.
I know someone out there can say something. Sure it's a Polk forum but we're all adults here (for the most part heh).
Anyone? Beuller? Beuuuuuuuuller.......? -
its not often i actually shut my mouth, but in this case i am --- only cuz i have no idea what to say... i dont know the product well at all ( heard many good things about boston, listened to a few to the point i'd consider buying them...
sposed to be some of the nicest 500+ w subs out there.The Artist formerly known as PoweredByDodge -
In other words I'm going to smoke the sub or amp pretty quickly with that combo. Right?
How would an MM104 perform with this 120W amp? Am I just dreaming when I talk about subs of this calibre with that amp? Should I just stick with the lower wattage stuff? (Boston generator, Polk GNX)
Thanks PBD.
I see you are a thundercats fan? Check this out. http://www.txraves.org/wavs/thundercatbloopers.mp3 -
I'd stick with the lower wattage stuff. Wanna use that amp for a long time? JL 10W0. Awesome subs, really low power requirements."The Big C"
Thanks, but I'm not much of a fan of JL's stuff.
I think I've finally decided on Image Dynamics. Either an ID10v.3 or an IDQ10v.2
Thanks! -
... one more audio soul saved from the near disaster of damnation by JL...The Artist formerly known as PoweredByDodge
