BAT VK-60 cap upgrade
BlueMDPicker
BlueMDPicker Posts: 7,569
edited September 2007 in DIY, Mods & Tweaks
William brought this absolutely stunning tube power amp by this afternoon.
It's the largest piece of tube audio gear I've ever seen! We upgraded the Jensen (pretty damn fine caps to begin with) coupling caps with V-Cap Teflon Film Tin Foil. I'll let William fill in the details. A couple of pics:
Post edited by BlueMDPicker on
    F1nut Posts: 52,304
    edited August 2007
    Nice!
    Pictures definitely don't do it justuce.
  • schwarcw
    schwarcw Posts: 7,360
    edited August 2007
    Very nice!
    Carl
  • W WALDECKER
    W WALDECKER Posts: 900
    edited August 2007
    Mike,I cant thank you enough.I have 15 Hrs on the .22uf V-cap TFTF Reference grade capacitors and all i can say is WOW! It has low level detail to die for. the Bass is some of the best that i have ever heard from either a tube or solid state amp! the midrange is still very beautiful which was a strong point with this design to begin with. all of the other performance parameters have been elevated to the same level of excellence as the midrange. i cant find any flaws in respect to how the VK 60 sounds now,its perfect! :cool: I will begin searching for another VK 60 to mod so that i can run a pair of these as 120 Wpc Monoblocks :)
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • Systems
    Systems Posts: 14,872
    edited August 2007
    Nice indeed,BAT build some of the tidiest looking tube stuff.
    Testing
    Testing
    Testing
  • BlueMDPicker
    edited August 2007
    Now that makes me smile.
  • W WALDECKER
    I now have 500+ hours on my V-cap MdBluePicker modded BAT VK60. According to the manufacturer 500 hours is the time that it takes to fully break in the TFTF Reference grade capacitors. i think i paid $360 + for four .22uf capacitors.if i had known the dramatic and entirely positive effect it would have on the sonic signature of my VK60 i would gladly have paid several times as much for the V-cap TFTF's! these Caps in the tube coupling positions are stellar performers and i highly recommend them to anyone considering such a modification. thanks....WCW III
