Harmony 659 issues
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,728
edited August 2007 in Electronics
Anyone else that's had their for a while had any issues?
I have two issues at the moment.
1 - The backlighting all the sudden is very dim. It's still there, but not really bright enough to be functional. That's an inconvenience, but doesn't affect overall functionality fo the remote.
2 - The USB no longer works, which means I can't update the remote, which does affect functionality and makes it useless.
I've had it for a while now, so I guess this is to be expected, was curious if anyone else had issues.
Post edited by AsSiMiLaTeD on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2007
    For the Hell of it did you try some fresh batteries?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • AsSiMiLaTeD
    edited August 2007
    Yeah, already did new batteries, and ruled out any PC issues, it's definitely the remote itself...
  • disneyjoe7
    edited August 2007
    Sorry, can I ask how long you owned it.
    I was thinking about buying one for a 2 harmony household.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Willow
    Willow Posts: 11,273
    edited August 2007
    The only issue I have had with my H659 is that I dropped it once when trying to stop my mother inlaw's dog from peeing on our carpet (she was 4mths old). Since then it sometimes turns off when it's just sitting there. Major Pita cause I'm not paying attention so I hit a button and it turns it all off :mad: .
    Have you called Harmony CS ?
  • Ricardo
    Ricardo Posts: 10,634
    edited August 2007
    I've had mine for probably two years now and love it as the first day. Only issue is that the batteries need to be changed :)
    SOPA
