Some Good Bookshelf Speakers..
FittyFieFo
FittyFieFo Posts: 482
edited September 2007 in Basic Hookup/Wiring Questions
I've been looking around for some good bookshelf speakers. Budget: $300. There any good bookshelf speakers that provide some good bass and good treble. Been looking at the RTI4's, heard some reviews saying there are no bass, but awesome treble. I like to hear some bass from the bookshelf speakers. Let me know if you guys have any suggestions. I just recently bought the center piece speaker: csi30.
Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables
Post edited by FittyFieFo on
  • dkg999
    dkg999 Posts: 5,647
    edited August 2007
    If you have the CSi30 center, then you should look for the Rti38 or Rti70 for your fronts. You should be able to find Rti38's within your budget. The Rti28 would also work, but it has less bass output than the 38's. Are you planning on buying a sub?
    DKG999
  • FittyFieFo
    edited August 2007
    Well, for my front speakers. I have the RTI10's.
    My center piece: Csi30.
    I did look at the RTI38's, are they good?
    I don't plan on buying a sub till later. (I think I am becoming addicted to buying polk speakers)...
  • dkg999
    dkg999 Posts: 5,647
    edited August 2007
    If you have Rti10's for your fronts, then you need the CSi5 for your center channel. The CSi3 might work also. The CSi30 has a different tweeter in it and isn't going to give you a consistent presentation across your fronts. You really don't need to worry too much about base from your side or rear surrounds, the Rti4's or 6's would work fine.
    DKG999
  • FittyFieFo
    edited August 2007
    Aww damn, I just bought the CsI30 too... I'm a noob, will it even help to keep it then?
  • FittyFieFo
    edited August 2007
    I'll just resell it then...
  • carpenter
    carpenter Posts: 362
    edited August 2007
    your system will preform Best if the fronts and center are from the same series. The rears can be from a different series and even a different manufacture. if you properly amplify the fronts you should have enough bass. you might find that just using an AVR with the 10s leaves something to be desired with your lows.
    which AVR are you planing on using?
    "If the global crisis continues, by the end of the year Only two Banks will be operational, the Blood Bank and the Sperm Bank. Then these 2 banks will merge and it will be called 'The Bloody **** Bank'"
  • FittyFieFo
    edited August 2007
    I am using a Yamaha HTR-5890
  • FittyFieFo
    edited August 2007
    Would it sound good with just the RTI 10's and RTI 6's? Not getting the center piece...(Using the RTI6's as surround) (or back speakers)
  • carpenter
    edited August 2007
    FittyFieFo wrote: »
    I looked at the Yamaha's specs, it seems powerful enough. would it sound good? you tell me. IMHO, the gear you got is way more then just a startup kit. you can always add a stereo amp, to drive the 10s with more power.
  • dkg999
    dkg999 Posts: 5,647
    edited August 2007
    I would sell the CSi30, get the CSi5 for the center. A good center is critical for HT, and for music if you are using any of the DSP modes or SACD/DVD-A/Dolby 5.1, etc. You could easily get away with the RTi4's as the surrounds, although I would opt for the 6's if you can swing it.
    DKG999
  • FittyFieFo
    edited August 2007
    So if you can choose of one of the following, which one would you pick
    The csi5 or the rti6's?
    Which one?
  • FittyFieFo
    edited August 2007
    Are the RTI6 made to be put in back of you..or along with the front?
  • dkg999
    dkg999 Posts: 5,647
    edited August 2007
    The RTi6's can be used as fronts, side surrounds, or rear surrounds. I would buy a good center channel before I worried about side or rear surrounds.
    DKG999
  • FittyFieFo
    edited August 2007
    So is anyone selling their csi5? lol. Thank you for all the input. I'm getting greedy and wanting more..Is the center piece good for music too?
  • dkg999
    dkg999 Posts: 5,647
    edited August 2007
    The CSi5 will be good for music. You might check onecall.com as they had some Polk speakers on sale. Good online e-tailer.
    DKG999
  • FittyFieFo
    edited August 2007
    And my final question, would my receiver (Yamaha HTR- 5890) power my RTI10's, csi5, and rti6's? I'm not going to get a subwoofer, read reviews that I don't need one with these set ups. Thanks!
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited August 2007
    In my Honest opinion... Having a home theater without a sub would be like putting a 4cyl in a Corvette! I ASSuME this is for HT?
  • engtaz
    engtaz Posts: 7,674
    edited August 2007
    I like Monitor 5's.
    engtaz
  • FittyFieFo
    edited August 2007
    Yeah you're right, I love bass. I think I'm going to go with:
    RTi10's
    RTi6's
    PSW505.
    Only things I can afford right now..
  • phileth
    phileth Posts: 22
    edited August 2007
    FYI-
    Crutchfield has the Rti6 on sale for $279 per pair, free shipping. Excellent customer service. Highly recommended.
  • RaysR6
    RaysR6 Posts: 28
    Monitor 40s, hands down I love mine.
  • impronto
    impronto Posts: 25
    i'd go with the rti6's. great value with awesome sound
