Anybody make DIY interconnects?
hypertone
I'm thinking of making my own interconnects. The main reason is that I can make some for next to nothing, and I think that they could possibly turn out as good as anything you can buy. I also love soldering and DIY projects.
I'd like to try some using coaxial TV cable. I seem to remember that this stuff has 1Mhz of bandwidth, and the center connector is a fat solid core of copper. I know from experience that it is excellent at rejecting noise. I think it would work great.
I also thought about using either STP ethernet cable, or some studio grade Mogami microphone cable.
What are your thoughts and experiences. Has anyone tried this?
Post edited by hypertone on
PM sent about connectors.
I ve used this coax from Canare to make a digital cable but it also works great as an IC .It has a stranded center conductor so it is much more flexible than coax with solid core center.I used Neutric RCA's(see link) but the Canares are also decent.http://www.canare.com/index.cfm?objectid=0D01B44F-3048-7098-AF1C088D26068A8A http://www.partsexpress.com/pe/pshowdetl.cfm?&Partnumber=092-114Testing
Testing
Testing -
Ok, I just built some cables using the Canare Star Quad microphone cable. That is some good cable. I used 2 of the wires for positive and 2 for negative. I terminated the shield at the source end, but left if disconnected from the destination end. They sound great, I noticed a big improvement immediately over my generic cables. $14 for 2 meters of cable and 4 Neutrik connectors.
Just bought em locally at a place that sells equipment for studios/live sound.
Great glad they made an improvement for you and the cost was far less then you would pay for big name cables.Testing
Testing
Testing -
Good Stuff!
I like twisted pairs made from 30-ga, varnish-insulated magnet wire. A teflon jacket makes them a bit more robust, but I haven't had any trouble with 'nude' ones in permanent installations.
They sound very good, IME and IMNSHO. -
mhardy6647 wrote: »I like twisted pairs made from 30-ga, varnish-insulated magnet wire. A teflon jacket makes them a bit more robust, but I haven't had any trouble with 'nude' ones in permanent installations.
Do you twist in a third shield or just use the two?Vinyl, the final frontier...
I've only made twisted pairs; a shield could be well worth trying though, now that you mention it.
From what I've read you only connect the third wire to one side or the other (not sure which) and wrap it or braid with the other two. Been reading about this stuff because I would like to try one with silver wire.
madmax
The source side. You don't want to connect it to the target side because you will be passing any noise towards the output. -
All of mine are homemade (RG-6) and they work great. Works great for long sub interconnects using RG-6 with F connectors and F to RCA adapters at the ends.My 7.4.4 DIY 4k Home Theater:
Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
Polk LSiM 702s x 4 on the Ceiling Atmos speakers
Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
Denon X3700H Emotiva XPA11 Gen 3
XBox One X 4k & BD and streaming
Panasonic UB-420 4k player
HD-A35 HD DVD
Oppo BD-103D for hirez audio
Technics SL-D2 TT, Grado Gold Cartridge
JVC DLA-RS2100/NZ7 projector
Silver Ticket 135" microperf AT screen
Berkline 090 electric recliners with Aura Bass Shakers
