Anybody make DIY interconnects?
hypertone
hypertone Posts: 150
edited September 2007 in DIY, Mods & Tweaks
I'm thinking of making my own interconnects. The main reason is that I can make some for next to nothing, and I think that they could possibly turn out as good as anything you can buy. I also love soldering and DIY projects. :)
I'd like to try some using coaxial TV cable. I seem to remember that this stuff has 1Mhz of bandwidth, and the center connector is a fat solid core of copper. I know from experience that it is excellent at rejecting noise. I think it would work great.
I also thought about using either STP ethernet cable, or some studio grade Mogami microphone cable.
What are your thoughts and experiences. Has anyone tried this?
Post edited by hypertone on
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2007
    PM sent about connectors.
  • Systems
    Systems Posts: 14,872
    edited August 2007
    I ve used this coax from Canare to make a digital cable but it also works great as an IC .It has a stranded center conductor so it is much more flexible than coax with solid core center.I used Neutric RCA's(see link) but the Canares are also decent.http://www.canare.com/index.cfm?objectid=0D01B44F-3048-7098-AF1C088D26068A8A http://www.partsexpress.com/pe/pshowdetl.cfm?&Partnumber=092-114
    Testing
    Testing
    Testing
  • hypertone
    edited August 2007
    Ok, I just built some cables using the Canare Star Quad microphone cable. That is some good cable. I used 2 of the wires for positive and 2 for negative. I terminated the shield at the source end, but left if disconnected from the destination end. They sound great, I noticed a big improvement immediately over my generic cables. $14 for 2 meters of cable and 4 Neutrik connectors. :)
  • Systems
    edited August 2007
    Wow,how did you get the cable and cons so quickly?
    Testing
    Testing
    Testing
  • hypertone
    edited August 2007
    Just bought em locally at a place that sells equipment for studios/live sound.
  • Systems
    edited August 2007
    Great glad they made an improvement for you and the cost was far less then you would pay for big name cables.
    Testing
    Testing
    Testing
  • hearingimpared
    edited August 2007
    Good Stuff!
    mhardy6647 Posts: 35,501
    edited August 2007
    I like twisted pairs made from 30-ga, varnish-insulated magnet wire. A teflon jacket makes them a bit more robust, but I haven't had any trouble with 'nude' ones in permanent installations.
    They sound very good, IME and IMNSHO.
  • madmax
    madmax Posts: 12,434
    edited August 2007
    Do you twist in a third shield or just use the two?
    Vinyl, the final frontier...
    edited August 2007
    I've only made twisted pairs; a shield could be well worth trying though, now that you mention it.
  • madmax
    edited August 2007
    From what I've read you only connect the third wire to one side or the other (not sure which) and wrap it or braid with the other two. Been reading about this stuff because I would like to try one with silver wire.
    madmax
  • hearingimpared
    edited August 2007
    madmax wrote: »
    madmax
    The source side. You don't want to connect it to the target side because you will be passing any noise towards the output.
  • rtart
    rtart Posts: 854
    All of mine are homemade (RG-6) and they work great. Works great for long sub interconnects using RG-6 with F connectors and F to RCA adapters at the ends.
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
