Help!
gacole2000
gacole2000 Posts: 255
edited January 2003 in Speakers
Upon moving I discovered that the tweeter on my CS400 has become slightly pushed in. Is there any way to restore it to its original form? Further, will this seriously effect the sound quality?
AVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One
Post edited by gacole2000 on
    F1nut Posts: 49,865
    edited January 2003
    Gentle suction should solve your problem.
  • gacole2000
    edited January 2003
    How would I do that, a vaccum is probably too much?
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
  • gacole2000
    edited January 2003
    Cool! Problem solved, I cranked it up a little and it went away!
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
    F1nut Posts: 49,865
    edited January 2003
    I did it with a shop vac. I put my hand around the end of the hose and slowly brought it closer to the tweeter. If I remember correctly, it was about a inch or two away when it popped out. You could also try to pop it out by pressing gently around the indented area with your fingers. You won't harm the tweeter by touching it.
    F1nut Posts: 49,865
    edited January 2003
    Ah, excellent!
  • gacole2000
    edited January 2003
    Thanks for your help!
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
    F1nut Posts: 49,865
    edited January 2003
    Anytime :D
  • gacole2000
    edited January 2003
    I was so careful I just felt sick about it, as you can well imagine.
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
    F1nut Posts: 49,865
    edited January 2003
    Yep! If you really want to feel sick, wait 'till you see one smoke!
