Help!
gacole2000
Upon moving I discovered that the tweeter on my CS400 has become slightly pushed in. Is there any way to restore it to its original form? Further, will this seriously effect the sound quality?
AVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One
BR: Samsung 1600
Center: CS300
Sides: FX1000
Rears: RT/FX
Remote: Harmony One
Post edited by gacole2000 on
Gentle suction should solve your problem.Political Correctness'.........defined
President of Club Polk -
How would I do that, a vaccum is probably too much?AVR: Yamaha RX-V661
BR: Samsung 1600
Center: CS300
Sides: FX1000
Rears: RT/FX
Remote: Harmony One -
Cool! Problem solved, I cranked it up a little and it went away!AVR: Yamaha RX-V661
BR: Samsung 1600
Center: CS300
Sides: FX1000
Rears: RT/FX
I did it with a shop vac. I put my hand around the end of the hose and slowly brought it closer to the tweeter. If I remember correctly, it was about a inch or two away when it popped out. You could also try to pop it out by pressing gently around the indented area with your fingers. You won't harm the tweeter by touching it.Political Correctness'.........defined
Ah, excellent!Political Correctness'.........defined
Thanks for your help!AVR: Yamaha RX-V661
BR: Samsung 1600
Center: CS300
Sides: FX1000
Rears: RT/FX
AnytimePolitical Correctness'.........defined
I was so careful I just felt sick about it, as you can well imagine.AVR: Yamaha RX-V661
BR: Samsung 1600
Center: CS300
Sides: FX1000
Rears: RT/FX
Yep! If you really want to feel sick, wait 'till you see one smoke!Political Correctness'.........defined
