Help needed
sageleo
sageleo Posts: 170
edited August 2007 in Electronics
I just recently bought a toshiba hd dvd player model hd-a1. I thought that I finally had all the configuring done. For movies I use 5.1 analogs and for music cd's I use fiber optic and set receiver to 5 channel. Now when I watch a movie I get little to no bass hardly even noticable, I've gone to set up menu and done the speaker setting on the dvd player and still nothing. I was told that I can't adjust anything on my receiver because all processing is done with the dvd player. If someone could please give me some ideas as to what I can do I would greatly appreciate it. Thanks
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
  • MikeC78
    MikeC78 Posts: 2,315
    edited August 2007
    Try setting the speaker settings in the player to LARGE. You have your speaker settings in the AVR to small?
  • danger boy
    danger boy Posts: 15,722
    edited August 2007
    try setting all speakers to small.. and see what happens.. if you still get nearly no bass.. then it's some other settings.
    PolkFest 2012, who's going>?
  • danger boy
    edited August 2007
    you using the 5.1 analog inputs on your receiver.. and then listening to movies in direct 5.1 mode? that should be the right way to hook up the Toshiba player.
  • danger boy
    edited August 2007
    the Toshiba website doesn't even list that model :confused:
  • MikeC78
    edited August 2007
    DB,
    That's the first generation model. Website no longer lists it, and there is actually a 3rd gen on the way. Speculated to see them this fall.
  • danger boy
    edited August 2007
    ahhh ok.. but i couldn't even find a users manual for that model on their site. unless i didn't look hard enough.
  • sageleo
    sageleo Posts: 170
    edited August 2007
    I did try them on large and it didnt help. Instead of use sub out on my receiver should I run the sub off of my fronts through speaker wire?
  • MikeC78
    edited August 2007
    No. Did you fully update the player to the current FW 2.3?
  • danger boy
    edited August 2007
    try setting them to small. not large.. large sends bass to your fronts.. and you don't want that. you want the bass to go to your subwoofer.. set them to small. with an 80Khz crossover.
  • danger boy
    edited August 2007
    did you use the auto calibration in your receiver to set the levels? If not. try that. or get a sound level meter and do it manually.. i think the problem is your subwoofer volume is to low.. either on the rear of the Velo or in your receiver settings.
    good luck. keep at it.. we'll figure it out.. ;)
  • sageleo
    sageleo Posts: 170
    edited August 2007
    firmware I did it earlier today. I normally have my speakers set to small and I tried it at 80 Khz.
  • sageleo
    sageleo Posts: 170
    edited August 2007
    I have volume at 2/3 in a 10'x15' room. I did the autocalibration when I got the avr. But with 5.1 analogs the hk doesn't proccess the sound I had to set that also inside the dvd player. It's wierd tho cause when setting speakers levels u cant go up only down.
  • danger boy
    edited August 2007
    Ok, i'm out. I have nothing else to offer.
    good luck.. i'm sure there is a solution some where.
  • sageleo
    sageleo Posts: 170
    edited August 2007
    maybe I'm just dense but I'm still not understanding or doing what that forum said cause I'm still not getting any bass...
  • MikeC78
    edited August 2007
    Check your H/K for a +10dB boost option for the multichannel analogue SW.
    Carefully read the second link that I posted. Hope this helps.
  • sageleo
    sageleo Posts: 170
    edited August 2007
    Hey thanks mike I finally got it figured out. I really appreciate it thanks again.:)
  • MikeC78
    edited August 2007
    sageleo wrote: »
    Great!!:) How exactly did you resolve it?
  • sageleo
    sageleo Posts: 170
    edited August 2007
    Went into my avr osd and set sw setting to +10. Then on the player itself I went to speaker config and set all the other speakers to -5 and left sw at 0. Kinda funny really I did that last night and ran the test tone on the player itself and still couldn't hear any bass. I tried it again this morning and just left it and threw in the bourne supremacy and it sounded great. Thanks again for the links and the help.
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    danger boy wrote: »
    I dont mean to drag this thread on , but this quote doesnt sound right, danger.
    In a 5.1 system. The .1 LFE is a deticated channnel for bass. Wether or not the fronts are set to large are small, if sub (LFE) is "on" on the avr, the bass will be sent to the sub and the fronts. So if you dont have bass and your playing a DD or DTS disk then that means your sub is either too low or off, it doesnt matter wether speakers (any or all) are set to large or small.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • MikeC78
    edited August 2007
    Some receivers will not send LFE to the sub with the speakers set to LARGE in the AVR. Some receivers have a "plus" setting that will work around the LARGE speaker setting.
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    MikeC78 wrote: »
    Every receiver I have owned, when I switched to front, large, I had to manually go in the menu and turn the sub off. Other wise, it default to LFE + L/R
    But thats what I'm saying. If you get no bass from sub :
    1. Its turned off. Either in player or AVR.
    2. Volume (gain) too low.
    3. Its not plugged in the right jack.
    But the fact that the speakers are set to large doesnt necssarily mean the sub is not on.
    I just didnt want to confuse him into thinking just cause his speakers were set to large, ment that he would not get any bass from sub. He doesnt have to keep speakers on small.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
