Help needed
sageleo
I just recently bought a toshiba hd dvd player model hd-a1. I thought that I finally had all the configuring done. For movies I use 5.1 analogs and for music cd's I use fiber optic and set receiver to 5 channel. Now when I watch a movie I get little to no bass hardly even noticable, I've gone to set up menu and done the speaker setting on the dvd player and still nothing. I was told that I can't adjust anything on my receiver because all processing is done with the dvd player. If someone could please give me some ideas as to what I can do I would greatly appreciate it. Thanks
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Try setting the speaker settings in the player to LARGE. You have your speaker settings in the AVR to small?
try setting all speakers to small.. and see what happens.. if you still get nearly no bass.. then it's some other settings.PolkFest 2012, who's going>?
you using the 5.1 analog inputs on your receiver.. and then listening to movies in direct 5.1 mode? that should be the right way to hook up the Toshiba player.PolkFest 2012, who's going>?
the Toshiba website doesn't even list that model
DB,
That's the first generation model. Website no longer lists it, and there is actually a 3rd gen on the way. Speculated to see them this fall. -
ahhh ok.. but i couldn't even find a users manual for that model on their site. unless i didn't look hard enough.PolkFest 2012, who's going>?
I did try them on large and it didnt help. Instead of use sub out on my receiver should I run the sub off of my fronts through speaker wire?T.V.- Sony KDL50W800B
Vizio Sound bar- S4221W -
No. Did you fully update the player to the current FW 2.3?
try setting them to small. not large.. large sends bass to your fronts.. and you don't want that. you want the bass to go to your subwoofer.. set them to small. with an 80Khz crossover.PolkFest 2012, who's going>?
did you use the auto calibration in your receiver to set the levels? If not. try that. or get a sound level meter and do it manually.. i think the problem is your subwoofer volume is to low.. either on the rear of the Velo or in your receiver settings.
good luck. keep at it.. we'll figure it out..
firmware I did it earlier today. I normally have my speakers set to small and I tried it at 80 Khz.T.V.- Sony KDL50W800B
I have volume at 2/3 in a 10'x15' room. I did the autocalibration when I got the avr. But with 5.1 analogs the hk doesn't proccess the sound I had to set that also inside the dvd player. It's wierd tho cause when setting speakers levels u cant go up only down.T.V.- Sony KDL50W800B
Here you go...
http://www.avsforum.com/avs-vb/showthread.php?t=877056&highlight=A1+bass+issues
http://www.avsforum.com/avs-vb/showthread.php?t=748147
Some damn good info here. -
Ok, i'm out. I have nothing else to offer.
good luck.. i'm sure there is a solution some where.
maybe I'm just dense but I'm still not understanding or doing what that forum said cause I'm still not getting any bass...T.V.- Sony KDL50W800B
Check your H/K for a +10dB boost option for the multichannel analogue SW.
Carefully read the second link that I posted. Hope this helps. -
Hey thanks mike I finally got it figured out. I really appreciate it thanks again.:)T.V.- Sony KDL50W800B
Great!!:) How exactly did you resolve it? -
Went into my avr osd and set sw setting to +10. Then on the player itself I went to speaker config and set all the other speakers to -5 and left sw at 0. Kinda funny really I did that last night and ran the test tone on the player itself and still couldn't hear any bass. I tried it again this morning and just left it and threw in the bourne supremacy and it sounded great. Thanks again for the links and the help.T.V.- Sony KDL50W800B
danger boy wrote: »try setting them to small. not large.. large sends bass to your fronts.. and you don't want that. you want the bass to go to your subwoofer.. set them to small. with an 80Khz crossover.
I dont mean to drag this thread on , but this quote doesnt sound right, danger.
In a 5.1 system. The .1 LFE is a deticated channnel for bass. Wether or not the fronts are set to large are small, if sub (LFE) is "on" on the avr, the bass will be sent to the sub and the fronts. So if you dont have bass and your playing a DD or DTS disk then that means your sub is either too low or off, it doesnt matter wether speakers (any or all) are set to large or small.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Some receivers will not send LFE to the sub with the speakers set to LARGE in the AVR. Some receivers have a "plus" setting that will work around the LARGE speaker setting.
Every receiver I have owned, when I switched to front, large, I had to manually go in the menu and turn the sub off. Other wise, it default to LFE + L/R
But thats what I'm saying. If you get no bass from sub :
1. Its turned off. Either in player or AVR.
2. Volume (gain) too low.
3. Its not plugged in the right jack.
But the fact that the speakers are set to large doesnt necssarily mean the sub is not on.
I just didnt want to confuse him into thinking just cause his speakers were set to large, ment that he would not get any bass from sub. He doesnt have to keep speakers on small.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
