Which is better M5b peerless or M5b with RDO?
engtaz
engtaz Posts: 7,669
edited August 2007 in Speakers
I know Peerless has fuse and lamer post but which sounds better??? So far to me it's RDO.
engtaz
Post edited by engtaz on
  • Ricardo
    Ricardo Posts: 10,636
    edited August 2007
    I don't think the RDO is a direct replacement for the Peerless, so some crossover work would be required.
    I have the 7B's with Peerless and I don't think I want to change those tweeters...ever.
    SOPA
  • george daniel
    george daniel Posts: 12,096
    edited August 2007
    Peerless is my preference,,,put some tubes on those 5's.
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    HTrookie wrote: »
    Same speakers here... +++1
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
    heiney9 Posts: 25,432
    edited August 2007
    The RD0 is no slouch and has many of the great characteristics of the original peerless. Note: The RD0's are not a direct drop in replacement. Slight modification is nec. Also the x-over used in Polk's with the original peerless is slightly different than the x-over used with the sl2000.
    FWIW
  • fredv
    fredv Posts: 923
    edited August 2007
    Anyone has the peerless M5's (or M7 for that matter) schematic?? The trouble shooting sticky doesn't have it.
    -fredv-
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • fredv
    fredv Posts: 923
    edited August 2007
    Yup yup, I saw your thread, but it is unclear to me how the 2 resistors are wired. The newer M7's only have one resistor. Do you mind to take a look? In terms of the other parts (caps and inductors), all M7 except the SL2500 are pretty much the same. As a matter of facts, the xover of the SL2000 M5's and the M7 are the same!!! My gut feeling is that, the schematic of your peerless M7 is also the same as the peerless M5. Once the mystery 2 resistors wiring is known. It should be easy to convert my M5 to use peerless which I have a couple spares!!
    EIDT: forgot to ask, was the big cap 27uF or 34uF?
    -fredv-
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    34uf
    Look at the m10 schem. Delete the bypass cap, and put the values I have in place of all parts.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • fredv
    fredv Posts: 923
    edited August 2007
    Great, one more dumb a$$ question, which resistor is in series with the 0.23mH inductor, looks like the 2.7?
    Roy, sorry for thread jacking. I go with Peerless rather than RD0 for mine :-)
    -fredv-
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    Here is my modified m10 crossover to replicate my 7b crossover with peerless tweeter.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • engtaz
    engtaz Posts: 7,669
    edited August 2007
    I have both versions of Monitor 5's.
    1 has no fuse and I replace tweeters with RDO194's in it.
    1 has fuse and peerless tweeters.
    I was just looking for opinions about 1 vs the other.
    Listen to both RDO194 M5's are a little smoother in sound in my opinion.
    engtaz
