I need a good gaming CPU
zingo
zingo Posts: 11,258
edited October 2007 in Video Games
I am building a new gaming computer and have not decided on which CPU to use. I started looking at Intel's E6850 because of its 3GHz. Then I saw AMDs 6000+ which has the same 3GHz, but is half the price. However, upon reading more reviews, the 6000+ has lower benchmarks than the E6700. Now my head is spinning with the clock speeds, and benchmark tests, etc. Can you help me choose a CPU. Either of these CPUs sound good, but I am not dead set on either. Please help me!
PS. For reference I will be using an SLI mobo and a pair of 8800GTS
Post edited by zingo on
  • Systems
    Systems Posts: 14,872
    edited August 2007
    Core 2 for absolute sure. Only reason to think about AMD right now is that fact that they are dead cheap. Get the Core 2 Duo. My main machine is still an AMD X2 4400 (bought when it first came out) and my gammer before that was the AMD 3500+ when it was new. If I were to buy a box right now, no doubt, Core 2 duo or quad. Make sure you get the new 1333 MHZ front side bus and DDR3 models.
    I’m buying 2 $20000 servers at work right now, cant wait to get my hands on them. dual processor Xeon Quad cores running at 3.0 ghz and 1333 FSB. Imagine that horse power. The SQL server will have 24 gigs of ram. Exchange server will probably have 16.
    Testing
    Testing
    Testing
  • cheddar
    cheddar Posts: 2,390
    edited August 2007
    These multi processor chips are great. Used to be you had to buy an expensive server board to get more than one chip. Now you can plug more than one processor in the same slot. Now if they could only get the OS to take full advantage of them without having to go 64-bit...or get a decent 64-bit OS...
    Silverti's right, though. Go with the benchmark unless you're on a budget. AMD will always give you an advantage in price. They used to have the best gaming chips, but intel really came back strong with their latest offerings...
  • Shizelbs
    Shizelbs Posts: 7,433
    edited August 2007
    Intel is the chip to get right now. The best way to compare processors is to go to the Tom's Hardware website and search for the 2007 CPU charts. They compare all the current chips under a variety of tests and apps and graph the results.
  • duksbak
    duksbak Posts: 134
    edited August 2007
    Intel Core2Duo E6850
    3.0GHz@1333FSB
    4MB Cache
    Its what i'm getting.
    Television: Mitsubishi WD-57732
    Front R/L: Polkaudio RTiA7
    Center: Polkaudio CSiA4
    Rear R/L: Polkaudio FXiA4
    Subwoofer: Polkaudio DSW600
    A/V Reciever: Denon 2808
    DVD/SACD: Sony Playstation 3
  • zingo
    zingo Posts: 11,258
    edited August 2007
    Man, you guys are good. I think I will have to go with Intel's Core 2 set. Thanks for all the suggestions, and the CPU comparison page.
    Do ya'll think there would be much difference between the E6850 (3.0Ghz) and the E6700 (2.66Ghz) when playing games?
  • Sami
    Sami Posts: 4,634
    edited August 2007
    The Quads are supposed to overclock like crazy. Just something to think about.
  • ilikesound
    ilikesound Posts: 355
    edited September 2007
    don't worry about clock speeds. that's probably the least important thing to focus on when choosing. as long as the rest of your computer is good, then you shouldn't notice. think about just how much math a 2.66g processor can do in one second.
    At Home:
    Panasonic 42'' TC-L42U12 LCD
    Pioneer VSX-80TXV
    Toshiba HD-XA2
    Sony PS3 - psn "metalguitars"
    Xbox 360 - gamertag "giggidygiggidy"
    Panamax 4300EX
    Polk RTi8's
    Polk CSi3's
    Polk FXi3's. (x2)
    Martin Logan Dynamo (x2)
    Audioquest interconnects and wires.
    Away From Home:
    JVC HDR-50
    stock system in new car for now:(
  • shadowofnight
    shadowofnight Posts: 2,735
    Lasareath wrote: »
    Very Nice!
    15,000 rpm SAS Drives I Assume?
    I use arrays of 15K 2gb/sec fibre channel drives for my 2 home servers with QLogic 2GB HBA's :)
    AMD had the gaming market cornered for a while, but Intel has now up and whooped their collective behinds . I worked for Intel for 2 years ...3 years ago...we were developing the stuff you are seeing now...back then...that was cool.
    The actual job at Intel sucked though....being in final test at Intel you were the technician/engineer/and the stinking operator of all the toolsets that ran the product...engineering part cool...tech part was my bread and butter...being an operator and having to actually keep track of the batches of product and run them in the tools sucked badly. And you dont even get a discount on the cpu's ;)
    So buy the best Intel cpu you can afford...
    The first rule of Fight Club is you don't talk about Fight Club
  • krabby5
    krabby5 Posts: 923
    I just ordered a Q6600..those things have really dropped in price..
    that along with the 8800 GTS card..
    pc gaming is fun again for me without dropping $2k:D
    Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
  • PADZZ
    PADZZ Posts: 83
    Silverti wrote: »
    And to think it'll be obsolete in a few years. Freaking hate buying new computers.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    I've heard from numerous places on the net that the E6750 is the best bang for the buck.I built an AMD 64 4000+ machine at the beginning of the year, and wish I would have stuck with the Intel. This is the first time I have built an AMD machine for my self, and wish I would have stayed with Intel. My 3 year old P4 2.4 machine is just a little slower than my new amd rig, but the Intel mulitasks a lot better, and faster.
  • shadowofnight
    PADZZ wrote: »
    More like a few months....
  • RaysR6
    RaysR6 Posts: 28
    get a Core 2 duo for about 300$ at newegg, the clockspeed war is not as significant as it once was, the GPU you have will be just as important for gaming.
  • zingo
    zingo Posts: 11,258
    I ended up getting the E6850 (3.0gig) because of a price break at my local shop. The 1333Mhz FSB was also hard to pass up. I paired that with 4 gigs of 800Mhz RAM and my new computer is zipping along quiet well. Thanks for all the suggestions. Once again, no body treats me better than CP.
  • jamison
    jamison Posts: 35
    edited October 2007
    zingo wrote: »
    ...nevermind...
    Jamison White
