Refreshing Older Hafler Amp...
I also have to make sure it can withstand the heatMonitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
The WIMA's will be just fine.The Panasonic cap is a polyester cap.
Mouser has a WIMA polyester cap 10uF 50v, which is smaller than the 100v Panasonic.Testing
Testing
Testing -
Nelson Pass specs these Panasonic polyesters in many of his DIY projects.mhardy6647 wrote: »
The Panasonic film caps are OK sonically in my (albeit limited) experience. I used some as coupling caps in a Knight (Allied) 333 (a/k/a Pioneer SX-34) due to space constraints.Testing
Testing
Testing -
Oh while your at it I would change the bridge rectifier as well.It should only be $5 ish.Testing
Testing
Testing -
The what?
Ok..where is it and what does it look like?Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Here are some shots of what I am working with.
The first is a shot of the board
The second is of the huge PS caps.
I'm sorry the came out so blurry, **** web cam.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
It is the square thingy between the large filter caps in the 3rd picture of your first post.They can fail with age so it would be a good idea to change it when you change the caps.You must make sure it is wired correctly or things will get nasty.The polarity will be marked on it.Just use the one now in the amp as a reference.The what?
Ok..where is it and what does it look like?Testing
Testing
Testing -
Yes he does so they come highly recommended. If they are good enough for him I'm sure they'll be just fine for you."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Good call as well. You're in there might as well put new ones in then you don't have to worry about them."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
My thinking exactly.:)Yes he does so they come highly recommended. If they are good enough for him I'm sure they'll be just fine for you.Testing
Testing
Testing -
Here are how things are locatedMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
ohhh....the bridge where the PS wires and caps are tied into, in the middle.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Bingo thats it.ohhh....the bridge where the PS wires and caps are tied into, in the middle.Testing
Testing
Testing -
This...Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
From the pic it looks like it might be a bit tricky fitting the polycap.Does the top of the chassis sit real close to the top of the circuit board when its on?Testing
Testing
Testing -
Is this for adjusting the bias? I think its the 1k ohms trimpotMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
I would say the board is about 1/8 inch from touching the top case. Do you think that is why Hafler went with electrolytic?Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
There is a major size difference between a 16v cap and a 100v cap...I don think the 100v will fit, 50v maybe, but not 100Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Yes that appears to be the bias pot.But a word of advice NO TOUCHY.:eek: Improperly adjusting bias(too high) can damage the output transistors.Is this for adjusting the bias? I think its the 1k ohms trimpotTesting
Testing
Testing -
Oh GV...They have that market well in blood red...I dare not touch...
......But it is so damn tempting...lolMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Unfortunately film caps are generally rated at 50 or more volts.Electrolytics are made in low voltages to minimize their size.Ill check some catalogs for a smaller 10uf film type.There is a major size difference between a 16v cap and a 100v cap...I don think the 100v will fit, 50v maybe, but not 100Testing
Testing
Testing -
As are many things that can get you into s**t load of trouble and pain.:D...But it is so damn tempting...lolTesting
Testing
Testing -
But if all else fails, I should be good with electrolytic. I mean, if anything its not I'm going backwards right?
If I could see in person how large the 50v cap is. I might just order one and see if it fits.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Let me ask, Why does only one input have a resistor coming from the ground to the chasis? Is it for humm noise?Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
You could use an electroltyic if need be.But if all else fails, I should be good with electrolytic. I mean, if anything its not I'm going backwards right?
the 100v panasonic is about 1" long x .75"high x .30" thick.
It is possible to use some hot glue and mount it near the top of the board and run some short wires to the conection points.Testing
Testing
Testing -
I think I will stick with the WIMA 50v, might fit better without mods.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Yes just giving the size as guide,Im not sure about sizing of the WIMA but it should be smaller.I think I will stick with the WIMA 50v, might fit better without mods.Testing
Testing
Testing -
This is likely there to tie the circuit to chassis ground.Using a resistor instead of a direct connection avoids the possibility of ground loops which results in as you said hum.Let me ask, Why does only one input have a resistor coming from the ground to the chasis? Is it for humm noise?Testing
Testing
Testing -
Here is what I used to recap my DH-200:
(2) 36DY183F075BC2A Vishay/Sprague 75V 18000uf Computer Grade Screw Terminal Capacitor
(2) UVP1A471MPA Nichicon 10V 470uf Bipolar Cap
(2) UVP1C100MDD Nichicon 16V 10uf Bipolar Cap
(4) UHE2A101MPD Nichicon 100V 100uf Low ESR Cap
My DH-200 sounds great and the new caps are a definite improvement over the aging original electrolytics. I am the original owner of both the DH-200 and the Polk 10A's that it is driving.
When ordering replacements for the large filter caps be sure to check the height as many are too tall for the enclosure. The Vishay's that I used are the correct height and diameter. I ordered all of the parts from Mouser.
I would also suggest replacing the on/off switch as this is a known weak point in the DH-200. Mouser has a replacement switch of slightly higher capacity Carling P/N LTA201-TR-B/125N .
You can find the Bias adjustment procedure in the DH-220 manual on Hafler's Web site. It is the same procedure as the DH-200 but was omitted from the DH-200 manual. DC offset is not adjustable on the DH-200 so disregard that section in the DH-220 manual. Hope this helps.
