SR6500's front&back, nakamichi head... what amp(s)
rotormotor
rotormotor Posts: 6
edited August 2007 in Car Audio & Electronics
hi, i have a 3rd gen rx7 (used to have the bose system) but im in the process of removing it for something a bit "nicer" ) ;) . anyway, i wanted recommendations for amps that would be on par with the sr6500's that i have for front and back (yet to be installed) and my newly acquired nakamichi CD-700II deck? id like to keep the price below 800 as im already reallllly broke between the SR's and the nakamichi. thanks, heath :cool:
Post edited by rotormotor on
  • Kenji_lim
    Kenji_lim Posts: 56
    edited July 2007
    :) nice stuff..my alltime favorites hu nakamichi..maybe u should try Alpine amp as well..:D nice and clear sound for sound stage..:D
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2007
    The Polk 400.4 would be a good fit.
    Basically look for anything from a quality amp manufacturer that puts out 75-100 watts per channel.
  • mesquitehead
    mesquitehead Posts: 312
    edited July 2007
    I will be using a JL 300/4 for mine in an 07 Tundra....very nice crossover set up and cool design for voltage regulation.
    "Thats great... but how does it sound"
    http://www.burginmcdaniel.com/
    http://mixonline.com/gear/reviews/audio_burgin_mcdaniel_komit/
    Yamaha RX-A820 (networked with wireless bridge), Carver M-1.0t, Carver TFM-35, Carver C-1, Polk SDA1c's (x2 pair), Polk RTA 8tl's, Polk RTA 11tl's, Polk Monitor 5, Polk CS 400, Polk PSW 650, Rega Planar 3, Sony DVPNC555ES SACD/DVD, Panny 65" Plasma, Roku
    2007 Tundra 5.7 TRD DC
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
  • JoshParsons84
    JoshParsons84 Posts: 565
    edited July 2007
    I dunno bout Nakamichi, I just looked at their stuff and it doesn't impress me at all. I would've gone with an Alpine deck and Alpine amp
  • rotormotor
    rotormotor Posts: 6
    edited July 2007
    i just bought an audison vrx 4.300 .... im hoping that will be an ok match with the HU and the polk SRs.
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited July 2007
    You do know that he has a CD700II right?
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • Vestax
    Vestax Posts: 31
    edited August 2007
    Find an amp with decent processing and you should be fine. The new Alpine PDX amps are both power and space efficient. You should give them a try. :)
  • killerb
    killerb Posts: 390
    edited August 2007
    some of the best amps in the world are made by ZED AUDIO. made in the USA. the draconia would have been a excellent choice with the burr-brown DAC's.
    http://www.zedaudio.com/products.html
    kenwood excelon kdc-x991 h.u.
    Rockford Fosgate 360.3 DSP
    Rockford Fosgate POWER1000 running entire system
    Image Dynamics IDQ12 Sub
    Morel Elate 6 front stage
  • 1996blackmax
    edited August 2007
    Totally agree....Had those Zed amps been smaller, I would have bought a pair.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • killerb
    killerb Posts: 390
    edited August 2007
    thats the ONLY problem with them. if you have the room you cant lose!
