SR6500's front&back, nakamichi head... what amp(s)
rotormotor
hi, i have a 3rd gen rx7 (used to have the bose system) but im in the process of removing it for something a bit "nicer" )
. anyway, i wanted recommendations for amps that would be on par with the sr6500's that i have for front and back (yet to be installed) and my newly acquired nakamichi CD-700II deck? id like to keep the price below 800 as im already reallllly broke between the SR's and the nakamichi. thanks, heath :cool:
Post edited by rotormotor on
nice stuff..my alltime favorites hu nakamichi..maybe u should try Alpine amp as well..:D nice and clear sound for sound stage..:D
The Polk 400.4 would be a good fit.
Basically look for anything from a quality amp manufacturer that puts out 75-100 watts per channel.polkaudio sound quality competitor since 2005
I will be using a JL 300/4 for mine in an 07 Tundra....very nice crossover set up and cool design for voltage regulation."Thats great... but how does it sound"
http://www.burginmcdaniel.com/
http://mixonline.com/gear/reviews/audio_burgin_mcdaniel_komit/
Yamaha RX-A820 (networked with wireless bridge), Carver M-1.0t, Carver TFM-35, Carver C-1, Polk SDA1c's (x2 pair), Polk RTA 8tl's, Polk RTA 11tl's, Polk Monitor 5, Polk CS 400, Polk PSW 650, Rega Planar 3, Sony DVPNC555ES SACD/DVD, Panny 65" Plasma, Roku
2007 Tundra 5.7 TRD DC
Pioneer DEH-80PRS
Polk SR6500
SI BM 12" subs
Zed Gladius
Zed Deuce -
I dunno bout Nakamichi, I just looked at their stuff and it doesn't impress me at all. I would've gone with an Alpine deck and Alpine amp
i just bought an audison vrx 4.300 .... im hoping that will be an ok match with the HU and the polk SRs.
JoshParsons84 wrote: »I dunno bout Nakamichi, I just looked at their stuff and it doesn't impress me at all. I would've gone with an Alpine deck and Alpine amp
You do know that he has a CD700II right?Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
Find an amp with decent processing and you should be fine. The new Alpine PDX amps are both power and space efficient. You should give them a try.
some of the best amps in the world are made by ZED AUDIO. made in the USA. the draconia would have been a excellent choice with the burr-brown DAC's.
http://www.zedaudio.com/products.htmlkenwood excelon kdc-x991 h.u.
Rockford Fosgate 360.3 DSP
Rockford Fosgate POWER1000 running entire system
Image Dynamics IDQ12 Sub
Morel Elate 6 front stage -
Totally agree....Had those Zed amps been smaller, I would have bought a pair.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
thats the ONLY problem with them. if you have the room you cant lose!kenwood excelon kdc-x991 h.u.
