SRS 3.1 or SDA2
Jockos
Jockos Posts: 310
edited August 2007 in Vintage Speakers
Somebody on the outer islands is selling a pair of SRS3.1's for $300 and SDA2's for $150. He says the SDA2's needs a new tweeter. Any opinions or advice? I'd would have to arrange for shipping since I know these are pretty heavy.
Jockos
Post edited by Jockos on
  • ben62670
    ben62670 Posts: 15,969
    edited July 2007
    get the 2's
    Ben
    heiney9 Posts: 25,630
    edited July 2007
    Really depends which model year the 2's are. The later the better. I'd take the 3.1's over early model 2's anytime.
  • ben62670
    edited July 2007
    Yes buy both you can't lose on resale at that price:D . The 3.1's I have owned, and are an awesome speaker for HT, and stereo listening. The SRS'2 will give a much wider sound stage. For us to accurately answer your question we need to know room size, intended use, and which actual model of SDA-SRS2's they are. Either way you will need a high currant amp. Not a receiver.
    Ben
    Ben
    edited July 2007
    ben62670 wrote: »
    Ben
    He didn't say SRS 2's Ben, otherwise I would have recommended those over the 3.1's. He said SDA 2's :)
  • ben62670
    edited July 2007
    heiney9 wrote: »
    Thanks H9! I need to get some sleep!!!
    Straight up 3.1s
    No questions asked.
    Again thanks for catching that bad info I gave out.
    Again please disregard my earlier post. My **** muscle was wrapped way to tight around my cranium!:o
    Ben
  • engtaz
    engtaz Posts: 7,675
    edited August 2007
    3.1's go for it.
    engtaz
  • fredv
    fredv Posts: 923
    edited August 2007
    FWIW, this 3.1, http://sfbay.craigslist.org/sfc/ele/384457555.html, are asked for $550, it is a no brainer for $300 :-) Yes, it sounds better than the 2 as well. 150 is also a good price for the 2's. So, buy both if you have spare coins, you know you can get the money back when resell, probably more!!
    -fredv-
  • ben62670
    edited August 2007
    Run don't walk! IF in good shape they are at least half going rate.
    Ben
  • Jockos
    Jockos Posts: 310
    edited August 2007
    Aw shucks! The seller said he already has and interested buyer coming over today. The earliest I could fly over would be friday.
    Jockos
