sound system help
Gemini
I have a 95 corolla and i was trying to find a head unit and speakers to replace my stock stuff
basically i have a budget of 300-500 dollars and was thinking i was going to get
http://www.bestbuy.com/site/olspage.jsp?skuId=8222498&type=product&productCategoryId=cat03066&id=1166840027254
and these type s alpine speakers
http://www.bestbuy.com/site/olspage.jsp?skuId=7652658&type=product&productCategoryId=cat03076&id=1134701298137
for both the front and back, but then i kinda realized i would need an amp if i did get these speakers? but then now i don't know if i should be getting 3 way speakers for the front now or what, so i'm just kind of looking for some clarification on what I should get, thanks
Post edited by Gemini on
I have Alpine type S's, and you need an amp to get any sort of SQ out of them. Hopefully someone will chime in about advice on some Polk's that work decent with a head unit. Those Alpines really need an amp. Did I mention that they need an amp? Just had to stress that point.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
ben, I wasn't sure about your reply, did you say they need an amp?
my bad...i was jw tho
should i get an amp for those speakers you gave me too for better sq?
what kind of amp should i get for them or the type s's then?
