Mounting ceiling center and rear speakers
len1jane
len1jane Posts: 5
I just purchaced RTi8's and I am looking at a TCi80 for a center channel and TCi620's for rears. I have a drop ceiling in my basement with 2' squares. The TCi80 appears to weigh 10 pounds and the TCi620s weigh 3.25 pounds. Is there a way of supporting the speakers in drop ceiling or do I need to rethink this setup?
I have a Denon AVR 2105 reciever and I' m on a limited budget .
Post edited by len1jane on
  • da5176
    da5176 Posts: 42
    edited July 2007
    Can't you place the center channel on top of your tv? If not, there are mounting shelves that will let you put one on top of a tv.
    NOT MUCH, BUT IT'S ALL MINE!
    SONY 60" SXRD (HDTV)
    Explorer 8300HD (HD-DVR CABLE BOX)
    Toshiba SD-3750 (DVD PLAYER)
    Onkyo TX-SR702 (RECEIVER)
    Polk Monitor 60 (FRONTS)
    Polk CS2 (CENTER)
    Polk Monitor 30 (SIDE SURROUNDS)
    Polk Monitor 30 (REAR SURROUNDS)
    Mirage Omni S-12 (SUBWOOFER)
    Tripplite HT 1000UPS (POWER PROTECTION)
    Omnimount (CENTER CHANNEL SHELF)
    B-Tech BT34 (SURROUND SPEAKER MOUNTS)
  • Zamps
    Zamps Posts: 48
    edited July 2007
    I'm not sure the drop ceiling tile can hold the weight of the speaker. But what if you replaced the tile where the speakers are located with a more rigid material? Like a light weight wood that you can paint and texture to match the ceiling tile? Just my two cents.
    Display: Mitsubishi 52" WD-52527
    AVR: Denon AVR-1909
    DBS: DTV HR20-700
    DVD: Samsung DVD-P421
    Video Game: Sony PS3, Wii
    CD Changer: Sony CDP-CX335
    Fronts: Polk RT800
    Center: Polk CS400
    Surrounds: Polk TC80i (4)
    Sub: Polk PSW450
    Misc.: Monitor 5JR
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2007
    I consider a piece of 3/4" plywood 4X4' or 2X3' on the backside of the ceiling tile to support the speaker as this would spead the weight accross more ceiling support rails in the area. Just my $.02 I never tried that myself.
    Report back on what you did, and Welcome to Polk Forums.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • len1jane
    len1jane Posts: 5
    edited August 2007
    Thank You for your responces. I have decided to go with the Csi3 for my center channel and now have to decide between the tc60i and tc620i for my rear ceiling surrounds.
