silk upgrade tweeters are in!!
tom t
tom t Posts: 543
edited August 2007 in Vintage Speakers
hello guys,
i just put in the upgrade tweeters. install was a snap until i was all done and the right speaker had no sound coming from them. it was at that point i was asking myself why i did this in the first place,the 2,000's sounded good to me. thinking it might be one of the new ones i changed out one at a time with an old one to see if that solved it. no--it diddent#%@#$%^&. ok,im all calm now again. then i put back in all the 2,000's and still no sound,what the hell!!!. they worked yesterday??. then i decided it was time to check the amp rca's. a quick switch over and i had sound!!. back in the new tweeters and all is fine. rca's needed a better connection. well after 1 hour, they sound fine to me. yes,i know wait about 50 hours or so but after the wife goes to work later up the volumn goes and i will enjoy right away. the hell with the 50 hours break in time. will give my sound impressions in about a week or two but i cannot imagine they will bad. tom t
Post edited by tom t on
  • engtaz
    engtaz Posts: 7,675
    edited July 2007
    They sound better and are better looking.
    engtaz
  • dorokusai
    dorokusai Posts: 25,638
    edited July 2007
    The SL2000 & SL3000 tweeter stink. The RD replacement series is rock solid.
  • ben62670
    ben62670 Posts: 15,969
    edited July 2007
    Very nice setup.
    Ben
  • danger boy
    danger boy Posts: 15,722
    edited July 2007
    congrats..
    and enjoy the sweet sounds on your SRS's.
    PolkFest 2012, who's going>?
  • tom t
    tom t Posts: 543
    edited July 2007
    yes lasareath, i know. now if i can only find someone to do that for me......
  • avguytx
    avguytx Posts: 1,628
    edited July 2007
    Where are you located? There is someone around that would be glad to help you out, I'm sure.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • gdsk39a
    gdsk39a Posts: 28
    edited July 2007
    Hi, I am getting ready to order the 6503 and 6511 drivers for my massive polk SDA SRS's. Will order from Polk. I am also going to order 8 of the tweeters from Polk. What are these silk tweeters everyone is talking about, does polk sell these as replacements?
    What about a crossover box, Polk doesn't sell it anymore?
  • george daniel
    george daniel Posts: 12,096
    edited July 2007
    you can replace the caps and resistors on the crossover,,use the search function,as there have been many who have "gone there" before you,If you are hesitant to diy, I'm sure that someone will offer you help/assistence,, have fun,,get your learn on before you upgrade,,if you choose to diy---good luck,,and welcome to the club:)
  • schwarcw
    schwarcw Posts: 7,360
    edited July 2007
    deleted tonew thread
    Carl
