Rta
exalted512
Just wondering if anyone had one and what you thought about it? Or if anyone has any suggestions on brands to go with or things to stay away from?
Thanks!
-Cody
Thanks!
-Cody
I have RTA12b's is that what your asking? I like them a lot. Nice full warm sounding. I would recommend them.engtaz
Also have the 12b's with the peerless tweeter. I highly recomend them.
Grimster74 wrote: »Or do you mean Real Time Analizer (sp)?
Thats what I was talking about, sorry for the confusion. Peerless does make good stuff, I have their 8" XLS
Audiocontrol. Pricey but a quality meter.
Yea, I was trying to keep it under a grand...
I second the Audiocontrol piece. Excellent RTA.
They are on the high side but I know of a lot of people that have scrounged up used ones for $500'ish.
Pretty much any 1/3 octave RTA is going to be pretty steep tho.polkaudio sound quality competitor since 2005
These can be had for a reasonable price and include graphic and parametric EQ which you may or may not want to experiment with..http://www.behringer.com/DSP8024/index.cfm?lang=engTesting
Testing
Testing -
Ive been looking all over the place for a used one and cant find any
Looks like I'm going to be going with one I can run through my laptop.
If anyone is interested, here it is:
http://www.trueaudio.com/catalog1.htm
The software itself ranges from $40 (1/3 octave) to $100 (1/24 octave)
Youll need a good SC. Unfortunately, I didnt opt to get one on my laptop because I didnt think I'd need it. I got a Refurbished SB Audigy NX2 for $60 shipped off ebay.
Mic-Behringer ECM8000 ~ $50
Mic preamp ~ $85
The 1/3 octave for $40 is about the same as your $7-800 RTAs, 1/24 is more along the lines of your $2000 RTAs. Now I doubt that this is as good as your stand alone units, but I keep hearing from different people that the software itself is every bit as good, its your mic or sound card that will be the limiting factor.
Thats pretty damn cool! I dont have a laptop tho so it would be cheaper for me to buy a $1000 RTA! I really need to get a laptop.
Right now all Ive got is my trusty $20 Walmart SPL meter and a couple CD's with test tones on them.polkaudio sound quality competitor since 2005
Yea, its about time you join the new millennium. On a side note, Ive got carpet back in...and the amp rack is back in...and power wire is ran...dun dun dun! The end is closer!
![[Deleted User]](https://forum.polkaudio.com/applications/dashboard/design/images/banned.png)
