Find me an amp
mox
hey,
i'm not sure what I need. I think I want a 5-channel 80 wpc/8 ohm.
my receiver is a Denon avr 3400. I am pushing LSi9s(fronts). Currently it pushes them effortlessly but I think all the cool people have an amp so i need one too.
Can I get a starter ampfor $500 or so?
Take your pick:
http://electronics.listings.ebay.com/Power-Amplifiers_Multi-Channel_W0QQfromZR4QQsacatZ14973QQsocmdZListingItemList
Check out Niles, Adcom, Parasound, etc.... -
Cambridge Audio AZUR 640R
KEF IQ2C Center, Fronts KEF IQ1 , Rears KEF Ci302Q
Sub Outlaw LFM2
Panasonic Plasma 1080i (50u)
Sony DVP-NS70H (DVD)
Belkin Pure Audio PF31 Line Conditioner -
why are you looking at 80 watt/5 channel amps??
Get your read on as to what those LSI's need to sing.HT SYSTEM-
lsi 9's -
You could just spend that $300 - $500 on a good stereo (2 channel) amp for the 9's, then add another 2/3/5 channel amp when you get the rest of your speakers. That way you can give them the power to really open them up. 80wpc might not be a big difference from your Denon.
I know there are several brands that make both 2 and 3 channel amps so you can keep from having too many different brands/sounds in your system. Or, you can do the mono block route.
Check out B&K. They have good stuff for reasonable prices. I've owned 2 of their amps and loved them both.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
This is the reason I jumped into separate amps. Thought my 635 pushed my Monitors fine, but adding separate amps took it up a notch, especially for music. If it did that for my lowly monitors, you should see an even greater jump in quality with separate amps.
Cool people have amps. Really cool people have really big/powerful amps.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
auto_pilot wrote: »
definitely, get over to www.outlawaudio.com looking forward to the arrival of our 7500! Great products, American made, 5 year TRANSFERABLE warranty, great deals on their 2200's right now! That will give your LSi the power they long for, good stuff!Home Theater
Chane A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
2 - Channel
Polk RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
Premier Rack|Blue Jeans,Audioquest,Monster Cables| -
680 for a 6x80 NAD with a factory warranty here...
http://www.audioadvisor.com/prodinfo.asp?number=1NACI9060 -
80wpc is not going to do squat for the LSI series!
If you insist on being cool, I suggest you start reading up on what is generally recommended for power on the LSI's. If you don't want to cough up the money to get decent power, get rid of the speakers.
It's not about being cool, it's about giving the speakers what they need to sound & operate best.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Read up on what everybody else says you should push these speakers with. That NAD will sound nice but will not give LSi speakers the oomph they need. Go for an amp with at least 200wpc into 8 ohms.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
I have a B&K AVP5000, you can find those well below $500 used. Great match for LSi's.
Maybe a little over your budget, even used, the Marsh A200 amp really makes the LSi9's sing. I was experimenting with different power amps I had with a new to me pair of LSi9's. The A200 is 120 wpc, loads of reserve/dynamic power, and very good tonal qualities. If I were using the LSi9's for music only, the Marsh A200 might be my choice. It's overkill for HT in my opinion, but it really made the LSi9's come alive, even when compared to 200 wpc + amps I also have.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
thanks guys for all the great responses.
Lots of good info. -
I don't disagree with that. However he asked about 5x80 stating his AVR pushed them effortlessly (to him).
Even though the linked amp was a little above the price target with an extra channel,I imagine mox is just starting research.
I simply was giving an FYI on it. -
hey,
LSi9's are 4ohm speakers.
I'll second WilliamM2's suggestion;
http://www.emotiva.com/lpa1.html
The LPA-1 is 225watts@4ohms x 6
