how to make a volume control
WolfKiyoshi
WolfKiyoshi Posts: 96
edited August 2007 in DIY, Mods & Tweaks
was just wondering is there a cheap/easy way of making a volume control? i have an old receiver that i have plugged into an equalizer with a spectrum display.. well the problem is the output level is so high it peaks the damn thing and i don't get to see the pretty lights :@ the volume control doesn't control the output and i'd just like to cut it down just a bit.. any way of doing this?
Post edited by WolfKiyoshi on
  • honda cber
    honda cber Posts: 267
    edited July 2007
    maybe you could drop all of the eq bands by a few dB?
    gear list:
    1 down, 4 up....
  • Gaara
    Gaara Posts: 2,415
    edited July 2007
    Attenuators should work, for example Rothwell Attenuators. If you want volume control you could go for a basic passive pre, should be less then $100.
    If you are handy you could DIY, I think the Rothwells just have a resistor inside.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited July 2007
    A couple 100ohm (mono) audio taper pots across the outputs will do the job. Make sure you get audio taper, not linear. You can get some at your local parts haus for a couple bucks. If it cuts it too much, you could use 50ohm, but 100ohm is usually the perfect starting point for a basic passive volume control.
    Cheers,
    Russ
  • WolfKiyoshi
    edited July 2007
    the taper pots just splice into the audio cord right?
  • hypertone
    hypertone Posts: 150
    edited August 2007
    Just wire up a potentiometer, shouldn't cost you more than $10 for everything you need. The wiper is the output, wire the pos. input to B and ground to A. A 50K pot would probably be a good choice.
