Hooking up an equalizer
PolkFan1
PolkFan1 Posts: 130
I have found an old adc stereo equalizer and I am confused how to hook it up. I have an harman hardon HK3480 stereo receiver and a sony dvd/cd player. How the hell do I hook this thing up?
Post edited by PolkFan1 on
    treitz3 Posts: 20,239
    edited July 2007
    Run it thru the tape loop if it has one, that way you can engage/disengage with a button.
  • hoosier21
    hoosier21 Posts: 4,428
    edited July 2007
    you can hook it up to the tape loop, select what you want to hear, push the tape monitor button, and the EQ will will be in the signal path.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • hoosier21
    edited July 2007
  • PolkFan1
    PolkFan1 Posts: 130
    edited July 2007
  • PolkFan1
    PolkFan1 Posts: 130
    edited July 2007
    Hmm its not working. IM probably doing something wrong.
    Heres the back of the eq
    Shot with CYBERSHOT at 2007-07-14
    and the back of the receiver
    http://www.harmankardon.com/back.aspx?prod=HK%203485&cat=REC&sType=C&Region=USA&Country=US&Language=ENG&ImgName=HK3485B.jpg
    I do not have a tapedeck...just a sony dvd/cd player with the audio jacks hooked up the the cd jacks in the receiver.
  • hoosier21
    edited July 2007
    hook the outputs of the EQ to the receivers tape 1 input, the inputs of the EQ to the receivers tape 1 output. On the receiver, select CD (or whatever you have the player hooked up to, then push the tape monitor button on the receiver. Bingo you are now listening to the eq, if you want to hear the player without the eq, push the tape monitor buton again.
    have fun
  • Drumingman
    Drumingman Posts: 348
    edited July 2007
    If you're H-K is like mine, it doesn't have tape loops. I bring the CD/SACD player cables directly in to the Eq and run another set in the the H-K CD input. Operate as normal.
    If you're planning on playing SACD's the one EQ will only work on the one set of channels.
    For five channels you'll need 3 Eq's. I use 2 as I do not alter the center voice channel.
