Looking to Match Speakers to PSW505 Sub
Vicedaddy
Vicedaddy Posts: 13
I juts got The PSW505 Sub and I'm looking to add surround speakers to a Yamaha HTR-6090 receiver. So I need to know a good set to match to the sub/receiver...any suggestions. I guess I'm looking for help as I would like to get well matched speakers for $1500 ideally with the fronts being Floor standing. But I don't really know anything.
Post edited by Vicedaddy on
  • phuz
    phuz Posts: 2,372
    edited July 2007
    Check out the Monitor or RTi lines. They'd be perfect.
  • Vicedaddy
    Vicedaddy Posts: 13
    edited July 2007
    The room they are going into is 21 X 12
  • daboyz
    daboyz Posts: 5,207
    edited July 2007
    phuz wrote: »
    +1 for Rti's. For $1500 you should be able to get Rti8's,Csi5 and Fxi5's or a great bookshelf and have an excellent 5.1 system. Tomorrow I'll be getting the Csi5 and Rti6's to go with my Rti8's. It's gonna be awesome,baby!!:D
    treitz3 Posts: 19,991
    edited July 2007
    What speakers do you currently have for the fronts and center? My advise....match the timbre unless you are just looking for noise transmission.
  • marc32
    marc32 Posts: 5
    edited July 2007
    I also have the 505 sub with a Yamaha receiver. I'm using the RTi 10's up front, with the RTi 4's in the rear. Sounds great. Like posted earlier, make sure they're matched.
  • Vicedaddy
    Vicedaddy Posts: 13
    edited July 2007
    Yep like the last post...going with the PSW505, Rti4's Rti10's and CSi5 should be sweet...powered by Yamaha HTR-6090 and for viweing pleasure Samsung 56 inch DLP (1080p)
