Digital vs Analog Interconnect
fatchowmein
fatchowmein Posts: 2,637
I was surfing for inexpensive interconnects on monoprice.com and came across their Premium 2 RCA Plug. http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021803&p_id=2869&seq=1&format=2&style=
Here's the description...
"High quality stereo analog interconnects for your hi fidelity system.
These premium quality cables feature thick RG59u, 75 ohm coax cables with 22AWG solid copper center conductor and heavy duty gold plated, corrosion resistant connectors."
Here's my beef...
I thought you weren't supposed to use 75 ohm coax for analog interconnects??? I thought 75 ohm coax were for digital IC and component video???
Post edited by fatchowmein on
  • danger boy
    danger boy Posts: 15,722
    edited July 2007
    22AWG Cable
    that sounds a little small to me... 22 guage cables? :eek:
    "They are perfect replacements for the thin, generic interconnect that are typically thrown in when you by audio components."
    says it all.. just replacements for those thin, generic interconnects you get when you buy an audio component. doesn't say it's a step up, increases performace, or add's clarity or any of that stuff... so i'd be lead to believe it's pretty low quality stuff.
    PolkFest 2012, who's going>?
  • WilliamM2
    WilliamM2 Posts: 4,811
    edited July 2007
    22awg is the same size Signal Cable uses for their Analog Two cables, which start at $49. The inteconnects that come with components are as small as 36awg.
    Isn't it refreshing? A company that doesn't lie and claim magical abilities for cable. The build quality is very good, BTW.
  • Face
    Face Posts: 14,340
    edited July 2007
    I noticed a night and day difference going from monoprice "premium" analog cables to a nice set of cables, SignalCable, Alpha Core, etc..
    mhardy6647 Posts: 35,522
    edited July 2007
    75-ohm coax is well-night perfect for "interconnects" for line-level analog components.
  • NewOrlnsDukie
    NewOrlnsDukie Posts: 24
    edited July 2007
    Face wrote: »
    in what way exactly?
  • Face
    Face Posts: 14,340
    edited July 2007
    Clarity, especially mids and highs.
