I want the fastest Ipod Control
eloplayspolo
What is the fastest Head unit including GPS and DVD players for an ipod besides the apline one w/ out the CD player?
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Mosconi 6to8 v8
Post edited by eloplayspolo on
Depends on the Ipod you have I guess. Do you want built in GPS, or GPS available as an option? The Pioneer AVIC-D3 or AVIC-Z2 might fit the bill, or the Clarion MAX675VD with the outboard NAX nav. Lots of options.
Juan -
the AVIC-D3 is slow.2013 Toyota Prius
Mosconi 6to8 v8 -
I have the Alpine IVA-W205 and its ipod isn't horrible. It takes a second or two for text info when you hit next (annoying), but artist/song searching isn't bad. Plus it has DVD out of the box and you can dock a blackbird II navi (when it is released) inside the HU when in the car or eject it to take it with you when you leave the car.
H -
To some degree, it depends on the Ipod you are using (I'm using a Video ipod straight into a DEHP6900UB for example and its lightning quick, but it goes straight into the USB, as opposed to using the IB100II Ipod adaptor).
So, the answer might vary depending on what Ipod you are using.
Juan -
AVIC-D3 isnt slow...my co-worker has it and its as fast as his iPod...
i had the 6800 and it was slow to go through all my artists, but i used the ipod adapter.
Direct USB faster?2013 Toyota Prius
Mosconi 6to8 v8 -
The Pioneer DEH-P6900UB is perfect for what you want. It features direct USB control of the iPod and is much quicker than a conventional HU using a iPod adapter.
I may just end up building a PC for the car and running it off a 7" touchscreen and having all my music on the PC, i just am curious about the sound quality if i do that, and how it would be best to connect it to my amps.2013 Toyota Prius
Mosconi 6to8 v8 -
o wow i just found the DEH-P6900UB for only 200 bucks new, hmmmm.2013 Toyota Prius
Mosconi 6to8 v8 -
6900 is not GPS or a dvd player
heh im aware.2013 Toyota Prius
Mosconi 6to8 v8
