Can This Cause Any Damage?
VXR8
Here is a unique connection, not so basic :eek: ? I have the following connected to the same RTi10 speakers via the PSW505 sub:
1. Yamaha RX-V2700
2. Marantz SR-320 (early 80s receiver used for music).
Both are connected to my PSW505, then bi-wired out to the speakers from the sub. Separately, from the back of both receivers for the main speakers, I have speaker cables going to the speaker input of the PSW505.
I have the positive speaker leads from both receivers joined together at the sub end, into a banana plug into the PSW505, and the same for the negative set of leads as well.
I never have both the Yammie or the Marantz on at the same time and all appears to work OK :eek: . This gives me the best of both worlds - Marantz for all music and Yammie for HT / TV etc., but I am curious to the likelihood of possible damage to any of the components, or if the receivers will see a different load thinking there are more speakers etc?
Thanks in advance for any thoughts / advice :rolleyes: .
1. Yamaha RX-V2700
Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200
Main System
Denon - AVC-4700H
Emotiva - XPA-9
SVS - PB1000 x 2
Foxtel - iQ4
Sony K77A9G
Front Room System
Post edited by VXR8 on
I don't know how you have not blown one of them by now,Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
I agree with Hoosier21 not a good move, and you're damn lucky you haven't killed something as of yet.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Aussies are brave souls!!!! Well, I guess it works, at least so far, you might want to give Ken Swauger a call, but each amplifier brand has its own circuitry so what works once may not again with different brands, I used to do all kinds of crazy things when I was youngster and only blew up two amps I can remember.
RT1 -
Thanks hoosier21 and disneyjoe7 for the responses - so far so good
. Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
SVS - PB1000 x 2
Foxtel - iQ4
Sony K77A9G
Front Room System
Polk Audio - Legend L200 -
reeltrouble1 wrote: »Aussies are brave souls!!!! Well, I guess it works, at least so far, you might want to give Ken Swauger a call, but each amplifier brand has its own circuitry so what works once may not again with different brands, I used to do all kinds of crazy things when I was youngster and only blew up two amps I can remember.
RT1
Thanks RT1,
I'll check in with Ken as per your advice. The way I have been looking at it is the sub and the speakers are only getting 1 "live" feed at any time, as the alternate receiver is turned off.
Both appear to power the sub and speakers up normally when used on an individual basis, the only thing I really need to know I suppose is does the receiver that is powered off receive a signal back down the line? I'll check with Ken and go from there.
Thanks once again for your response
Main System
Denon - AVC-4700H
Emotiva - XPA-9
SVS - PB1000 x 2
Foxtel - iQ4
Sony K77A9G
Front Room System
yes. if you are transmitting signal from one avr, and it is hooked directly to another one, the speaker current is being applied to the output section of the other amp. honestly, i cant believe that you cant actually hear the interaction. does your yamaha have preamp outs? if so, do the marantz the way you have it, but use preamp-level signals for the other AVR. this electrically seperates the output sections of the two amps, thus eliminating potential for damage. you will have to revise your wiring scheme. otherwise, i agree with:
and recommend that you take appropriate action. i can just about promise you that you *will* destroy something if you ever do accidentally have both units powered up simultaneously.I don't know how you have not blown one of them by now,
agear list:
1 down, 4 up.... -
*Will* destroy something.... But what a light show followed by the "Smell"
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Get a speaker wire switch box.
+1, that just ain't right. Get a speaker switch box. -
Hi guys,
Thanks for all your feedback. I will get a speaker wire switch box, but in the short term I have separated the 2 amplifier inputs and plug them into the PSW505 as I use the different one.
I understand that it may have caused damage to some components, but is there a "logical" explanation of what it may have done, considering only one receiver was on at a time? This is the bit I cannot get my head around - that said I have certainly heeded all of your warnings and rectified the situation in the short term.
Thanks again for your feedback and anyone who wants to dip their toe in the water for the "logical" explanation, it would be appreciated.Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
SVS - PB1000 x 2
Foxtel - iQ4
Sony K77A9G
Front Room System
If you don't understand how anything could happen to the receiver that is turned off, disconnect the speaker wires from the dead receiver, turn up the volume on the live one and stick the leads to your tongue. In your logical world nothing will happen...................let us know.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Dennis,no need to be so cruel to the lad.......
Alligator clips to the sack would be much more acceptable.:pHT SYSTEM-
lsi 9's -
Dennis Gardner wrote: »If you don't understand how anything could happen to the receiver that is turned off, disconnect the speaker wires from the dead receiver, turn up the volume on the live one and stick the leads to your tongue. In your logical world nothing will happen...................let us know.
Hi Dennis,
Thanks - was going to try a more conventional method of a multi meter, but that wasn't available
. Had to re hook it up that way again and then tried your tongue test and nada, not a bit of current coming through :eek: - remember, both amps were hooked up into the PSW505 speaker "input", so maybe this eliminated the problem?
Anyway, as I state, it is now hooked up individually and I'll plug and play as required.Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
SVS - PB1000 x 2
Foxtel - iQ4
Sony K77A9G
Front Room System
Hey Tony,
As per above post to Dennis, your suggestion would have been great and probably the most excitement I would have had all day :rolleyes: , , but no current unfortunately
Cheers.Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
SVS - PB1000 x 2
Foxtel - iQ4
Sony K77A9G
Front Room System
