Can This Cause Any Damage?
VXR8
VXR8 Posts: 291
Here is a unique connection, not so basic :eek: ? I have the following connected to the same RTi10 speakers via the PSW505 sub:
1. Yamaha RX-V2700
2. Marantz SR-320 (early 80s receiver used for music).
Both are connected to my PSW505, then bi-wired out to the speakers from the sub. Separately, from the back of both receivers for the main speakers, I have speaker cables going to the speaker input of the PSW505.
I have the positive speaker leads from both receivers joined together at the sub end, into a banana plug into the PSW505, and the same for the negative set of leads as well.
I never have both the Yammie or the Marantz on at the same time and all appears to work OK :eek: . This gives me the best of both worlds - Marantz for all music and Yammie for HT / TV etc., but I am curious to the likelihood of possible damage to any of the components, or if the receivers will see a different load thinking there are more speakers etc?
Thanks in advance for any thoughts / advice :rolleyes: .
Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200
Post edited by VXR8 on
  • hoosier21
    hoosier21 Posts: 4,415
    edited July 2007
    I don't know how you have not blown one of them by now,
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2007
    I agree with Hoosier21 not a good move, and you're damn lucky you haven't killed something as of yet.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited July 2007
    Aussies are brave souls!!!! Well, I guess it works, at least so far, you might want to give Ken Swauger a call, but each amplifier brand has its own circuitry so what works once may not again with different brands, I used to do all kinds of crazy things when I was youngster and only blew up two amps I can remember.
    RT1
  • VXR8
    VXR8 Posts: 291
    edited July 2007
    hoosier21 wrote: »
    Thanks hoosier21 and disneyjoe7 for the responses - so far so good :p .
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • VXR8
    VXR8 Posts: 291
    edited July 2007
    RT1
    Thanks RT1,
    I'll check in with Ken as per your advice. The way I have been looking at it is the sub and the speakers are only getting 1 "live" feed at any time, as the alternate receiver is turned off.
    Both appear to power the sub and speakers up normally when used on an individual basis, the only thing I really need to know I suppose is does the receiver that is powered off receive a signal back down the line? I'll check with Ken and go from there.
    Thanks once again for your response :p .
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • honda cber
    honda cber Posts: 267
    edited July 2007
    yes. if you are transmitting signal from one avr, and it is hooked directly to another one, the speaker current is being applied to the output section of the other amp. honestly, i cant believe that you cant actually hear the interaction. does your yamaha have preamp outs? if so, do the marantz the way you have it, but use preamp-level signals for the other AVR. this electrically seperates the output sections of the two amps, thus eliminating potential for damage. you will have to revise your wiring scheme. otherwise, i agree with:
    and recommend that you take appropriate action. i can just about promise you that you *will* destroy something if you ever do accidentally have both units powered up simultaneously.
    a
    gear list:
    1 down, 4 up....
  • disneyjoe7
    edited July 2007
    *Will* destroy something.... But what a light show followed by the "Smell" ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • PolkThug
    PolkThug Posts: 7,532
    edited July 2007
    Get a speaker wire switch box.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited July 2007
    PolkThug wrote: »
    +1, that just ain't right. Get a speaker switch box.
  • VXR8
    VXR8 Posts: 291
    edited July 2007
    Hi guys,
    Thanks for all your feedback. I will get a speaker wire switch box, but in the short term I have separated the 2 amplifier inputs and plug them into the PSW505 as I use the different one.
    I understand that it may have caused damage to some components, but is there a "logical" explanation of what it may have done, considering only one receiver was on at a time? This is the bit I cannot get my head around - that said I have certainly heeded all of your warnings and rectified the situation in the short term.
    Thanks again for your feedback and anyone who wants to dip their toe in the water for the "logical" explanation, it would be appreciated.
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited July 2007
    If you don't understand how anything could happen to the receiver that is turned off, disconnect the speaker wires from the dead receiver, turn up the volume on the live one and stick the leads to your tongue. In your logical world nothing will happen...................let us know.
    tonyb Posts: 33,069
    edited July 2007
    Dennis,no need to be so cruel to the lad.......
    Alligator clips to the sack would be much more acceptable.:p
  • VXR8
    VXR8 Posts: 291
    edited July 2007
    Hi Dennis,
    Thanks - was going to try a more conventional method of a multi meter, but that wasn't available :( . Had to re hook it up that way again and then tried your tongue test and nada, not a bit of current coming through :eek: - remember, both amps were hooked up into the PSW505 speaker "input", so maybe this eliminated the problem?
    Anyway, as I state, it is now hooked up individually and I'll plug and play as required.
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • VXR8
    VXR8 Posts: 291
    edited July 2007
    tonyb wrote: »
    Hey Tony,
    As per above post to Dennis, your suggestion would have been great and probably the most excitement I would have had all day :rolleyes: , , but no current unfortunately :D .
    Cheers.
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
