Onkyo Fans Rejoice! TX-SR805 Very Cool!
scottvamp
I may just pick this receiver up very shortly. Very good reviews so far. At 51lbs it seems to have high current clean power. $999 at Crutchfield and Vann's for $899 (black is sold out and i do not know if they are an authorized dealer)both with no tax and Free shipping. I may simplify my system for now and put the Monster Amps aside or just use one for the my centers.
This unit seems to have it all and is a no brainer for people just getting into HT. As anyone getting into HD players.
Any thoughts/opinions? Reviews?
http://www.onkyousa.com/model.cfm?m=TX-SR805&p=i&class=Receiver
http://www.crutchfield.com/S-Ib1vm5gmWTZ/cgi-bin/ProdView.asp?g=10420&tab=detailed_info&i=580TXS805B#Input%20and%20Output%20Notes
Post edited by scottvamp on
I wish I would have went with the 8xx series for the pre-outs."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
At some point I am planning on upgrading to Rti12s. I was thinking I was going to have to get a separate amp to let them reach their full potential. Do you think the 805 will provide enough power so that a separate amp is not necessary?McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
Personally, yes, i believe you would be fine. This unit also switches to 6ohm mode to deliver even more power. That is what i will run mine at.
EDIT: Going to order it from Crutchfield on Friday. I also have a $20 coupon code. $3 for three day shipping. -
Thats what I thought about my 600 about a month after buying it. I will never make that mistake again. Its also the first piece of advice I try to give out. Always buy with preouts. -
Man, that thing sure looks like it has all the bells and whistles. I like the new look to the Onkyo AVRs. They've never been bad, but this is a much better visual presentation. I like the glowing knob.
This is a BEAST!
I like that it is a High current amp and that it uses a Burr Brown DAC. -
Just a note of caution. I always thought that an amp section with switches for low impedance loads limited the output to protect the amp and speakers. A high current amp that can handle 6 and 4 ohm loads shouldn't have these switches. Still a nice receiver. I like that Onkyo seems to be first out of the gate with support for TrueHD and DTS-MA.
My only complaint is that I wish it had more optical in's.engtaz
Its not a "switch" for say, it's a setting in the menu system. It should deliever a boost in the mid and low range. The unit may run a little warmer. I have cooling fans off my Monsters and they should work well with the 12v triggers. -
Does it do multichannel audio over HDMI?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
onecall has them on order for 899. (add to cart for discount price)
The 605 processes all the new formats also:
Onkyo TX-SR605S Silver 7.1-Channel Home Theater Receiver
$399.99 (add to cart to see this price) -
wingnut4772 wrote: »Does it do multichannel audio over HDMI?
Like for SACD? If their is such a thing, this unit probably does it. I know that question always comes up. I believe multichannel is an analog format.
****onecall has them on order for 899. (add to cart for discount price)****
Is OneCall an authorized dealer? I was going to go with Crutchfield because their customer service is as good as it gets.
Another side note on these new units is they use "Push Pull" Amplification, which i believe is the technology Bob Carver created for his Sunfire line. -
Onecall rocks. They actually called me up a week after I received my Onkyo TXSR700 and asked if I got everything hooked up okay.
No way in hell my wife is gonna let me upgrade the receiver for some time, but I want oneTesting
Testing
Testing -
SACD and DVD-A are digital formats, but because of copy restrictions they can't be sent over optical and must usually be decoded by the player and sent out over analog interconnects. I guess what's happening is that proprietary digital connections are being replaced by hdcp enabled hdmi connections. And this onkyo appears to be hdcp compliant and hdmi 1.3a to boot.
This comes from the manual:
You can connect speakers with an impedance of
between 4 and 16 ohms. If the impedance of any of the
connected speakers is 4 ohms or more but less than 6,
be sure to set the speaker impedance to 4 ohms (see
page 45). If you use speakers with a lower impedance,
and use the amplifier at high volume levels for a long
period of time, the built-in amp protection circuit may
be activated.
Doesn't sound like the amp section is full power 4 ohm stable. So that's why they have the extra menu setting to limit the output into 4 ohms. Very few receivers can handle 4 ohm loads well. So nothing against the onkyo, but your monster amps are much better amplification than this receiver can produce. -
Most receivers don't run at 4 ohms. Its pretty much a given. Running 4 ohms your probably using hi-end speakers and should have a separate amp. I have 8ohms speakers. But like i said the 6 ohms gives a good boost to the mid and low range. This receiver is a great value and is defiantly setting a new benchmark. I need to figure out the best way to run my dual centers. I may keep one of the Monsters in play. I should keep the Monsters for a speaker up grade one day.
Going to Vegas this weekend, i may pick my Onk up their. -
I just read this on Aufioholics.com
http://www.audioholics.com/education/frequently-asked-questions/connecting-4-ohm-speakers-to-an-8-ohm-receiver-or-amplifier
"NOTE: Some Receivers have an impedance selector switch. DON'T USE THEM! The manufacturer puts them there for UL approvals as well as easing consumer concerns about driving low impedance loads. These switches step down voltage feed to the power sections which will limit dynamics and overall fidelity. Keep the switch set for 8 ohms regardless of the impedance of your speakers and ensure proper ventilation of the Receiver."Testing
Testing
Testing -
It's 4 ohm stable and the switch is pointless. The Onkyo WRAT is very similar to the NAD Power Envelope in how it produces dynamic power. I hope they come out with an updated model along the NR1000 lines. I prefer the modular idea for future upgrades over simple firmware.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
OK, so after reading this from the link above, now I'm even more confused:
Although a particular loudspeaker may be rated for 4 ohms (nom), it may actually provide a more stable load for an amp to drive than another speaker rated at 8 ohms. This has to do with the inductive reactance nature of loudspeaker systems. A speakers impedance varies as a function of frequency. An improperly designed loudspeaker may have nasty impedance dips at certain frequencies. This may potentially drive an amp into oscillation if it becomes too problematic. A well designed 4 ohm speaker system will usually present a more ideal load to an amp than a poorly designed 8 ohm speaker.
I have a 4 ohm center channel and 6 ohm surrounds. How do I determine if my speakers are designed to provide a stable load for my receiver?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Silverti, good research. We Polkies in the know have ALWAYS given that advice. If you need to run 4 ohms, go with separates. Their are always a few exceptions but no much starting at double the price of this unit. The Polk RT line are very efficient speakers but can crave clean power as i have noticed with my Monster Amps. LSi is a whole other creature. Of course i did read a review with someone owning LSi's and were very happy with the 805 over their previous Denon. -
I have a 4 ohm center channel and 6 ohm surrounds. How do I determine if my speakers are designed to provide a stable load for my receiver? -
scottvamp,
Look into similar units from Denon, Rotel, Outlaw, and others and pick what best for you. At that price you have choices. I have owned Onkyo before so I am not putting Onkyo down, just at that price you have choices.engtaz
Having a quality low ohm amplifier, will come into play. The bottom line is you have mismatched speakers. Therefore producing different loads to the channels of your amplifier. It could possibly have a negative sound quality or stress to the amp.
I figured it would be OK with a 5.1 setup since I don't run my fronts from the receiver, so it's not working too hard. Is this correct?
Nevertheless, the whole point of what I quoted was that some 4 ohm speakers may be an easier load on the receiver than an 8 ohm speaker, so WTF?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
scottvamp,
But even the new Denon units that decode TrueHD and DTS-MA aren't released yet. Not much choice in any price range for an hdmi 1.3 compatible receiver that decodes the advanced codecs...you can't even get players that decode DTS-MA... -
You don't need a TruHD receiver to enjoy TruHD, as long as the player can decode it, the receiver can receive it via HDMI."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
scottvamp,
engtaz, thanks for the input! Onkyo is the first to put the ball through the hoop. Being an Onkyo fan, i have no issue buying from them. -
Nothing............, i want to make a decision in the next couple days. No HD audio bitstream on the PS3.Onkyo has the 806 coming out in the fall. Guess i can hold off for now. Have to put up with my current setup.:rolleyes:
