Got bored....
dudeinaroom
so i decided to take my cheap sony turntable apart and bypass the internal preamp. My Adcom pre has a built in tt-pre in it so I said what the hey. was super easy, took me about 10 minuets to do(it took me longer to round up tools:eek:) I took the pre amp board, and remover the wires from it, then took the left and right lead from the tone arm, and soldered them directly to the RCA leads. I took the ground wire from the tone arm and connected it to the rest of the grounds, which I soldered another wire to and hooked up to the ground post on the back of my pre amp. I'm not sure what cartridge is in it, I only know the stylus has been replaced, with what I don't know, and I do not see any markings on it.
First impressions:
The treble is more detailed, and a little bright, but not overly bright. Center stage images are solid and pinpoint( the singer does not sound as if they have a 4 foot wide mouth). The sound stage has also widened I now have a sound stage from the turntable that reaches out side of my speakers. the bass is a little more laid back:( , but diggs deeper:cool:. All in all every thing has more resolution, not leaps n bounds, it's a marginal difference, but I can pick it up and that is all that matters. I've only done a brief listening, but I think this is a change I will be will be living with.
Now just to see what settings work best on my Adcom.
Later,
dude
First impressions:
Later,
dude
Post edited by dudeinaroom on
You need to get a job Dude:pPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I'd love some cables. I would have replaced them if i had something to replace them with. Now if I could jut find a job it would be golden.
dudeinaroom wrote: »I'd love some cables. I would have replaced them if i had something to replace them with. Now if I could jut find a job it would be golden.
Sorry I had to pick on ya. I'm in the same boat!
Ben -
I caught the smiley it's cool.
