The appropriate AV-Amp
mauro_ferrante
Hello, I've already decide to buy a pair of RTi10 front speakers. I wonder if you could give me some advice concerning the AV-Amp. First I'm going to make them work as a 2.0 audio system, and once I have save the rest of the money I'm going to upgrade it to a 5.1 system.
So according to your experience which is the appropriate AV-amp I should buy?
Post edited by mauro_ferrante on
I would recommend buying a used Adcom GFA-555. What do you have for a PreAmp?
Ben -
I don't have no PreAmp, why?
The Amplifier only amplifies the signal. You need a pre amp to send the signal to the amplifier. I would look for an HK, or Denon receiver with pre outs, and then get an Amplifier later. Just make sure the Receiver has Pre Outs.
Ben -
I was yhinking about a Denon as an AV-receiber. The model I was looking at has pre outs. But what would you recomend as Amplifier, the GFA-555?
Adcom amps offer very good performance.
other brands to consider would be B&K, Outlaw Audio, Parasound, Sunfire if you have more money to spend.
get a 5 channel amp.. since later down the road you said you will be going with a 5.1 system.. then you'll be all ready to go.PolkFest 2012, who's going>?
