42' - 50" LCD/DLP rear projection TV
moraks
moraks Posts: 49
edited June 2007 in Electronics
I am looking to get a 42 - 50 rear projection HDTV , I am currently looking at the samsung or toshiba, do you have any recommendations or word for the wise?:confused:
thanks
Post edited by moraks on
  • JimBRICK
    JimBRICK Posts: 1,543
    edited June 2007
    sony grand wega KF50E200A Awesome tv
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited June 2007
    Well, I know I am not the only person to have a problem with Samsung DLPs around here....I have had my replacement Toshiba for a couple of weeks, and I really think an all around better product...The remote is a lot higher quality and easier to use, input labeling, and it is easier to setup as well....Oh yeah, the picture is better on this one than the Samsung I had as well...
    Check out www.secondact.biz .They have a lot of good deals....
  • mantis
    mantis Posts: 17,455
    edited June 2007
    I think the SOny's are the best overall looking. Samsung's are nice bu they break.
    Go Sony dude.
    Dan
    Dan
  • phipiper10
    phipiper10 Posts: 961
    edited June 2007
    I've seen the other guys who have had problems with their Samsungs. I personally have had no problems and I'm coming up to 2 1/2 yrs and I'm completely satisfied. (Maybe I have a later generation of the light engine which seems to be the problem for the other guys)
    I have the 42" DLP. (HL-R4266W) I bought based on the fact, at least when I was looking, that at 2 different stores it was the best looking tv. I wasn't even planning on getting a tv at the time. It just stood out as a great picture.
    I realized I had a friend with the same model who loved his. The price and picture were great and the impending superbowl 2 years ago pushed me over the edge into purchasing.
    Good luck.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • JimBRICK
    edited June 2007
    if your looking to spend a little more money the SXRD tv's this year are WILD. We set one up 1080p and WOW. Not to shabby the chassis are black too now so they even look good when their off
    2 CHANNEL
    Under construction
  • moraks
    moraks Posts: 49
    edited June 2007
    I will be going out next week to see what is out there. thanks everybody
  • shawn474
    shawn474 Posts: 3,052
    edited June 2007
    Check out Panasonic as well. They make a very reliable product and typically are not as expensive as the Sony's.
    Shawn
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • fireshoes
    fireshoes Posts: 3,167
    edited June 2007
    I would say Sony SXRD overall for a microprojection, but a lot of people like the really bright image of the Samsung HLTxx76s series.
