How in the heck do you hook these up?
T_Unit616
Ok. I just got my 10" Pioneer TS-W251R. Now, I was used to hooking up older type subwoofers. But I have no clue about these. The only thing I can tell about them is that they are basically caps of som sort, black and red. that can be pushed up. They slide up and down. Sorry if my info is confusing, just ask and I'll try to help out with more.
Post edited by T_Unit616 on
push down on the terminal"cap" and insert wire on the side of it, let go
Does it have to be on the side? I am having troubles getting the wire in on the side. It can't go right through the front?
When you press the spring post in, it will align two holes on the side to form one hole, stick your speaker wire in, then let go.
just put it where the hole is top,bottom,left,right,Half way to hell......just put it in the hole.
The wire wants to go home. The hole is his home. Send the wire to his home.
Lol alright I figured it out thanks guys.
LOL- never quite thought about it that way. Mind if I adapt that slightly...for use with the wifey? If I put it in those terms, it can't cause a headache... -
dudeinaroom wrote: »just put it where the hole is top,bottom,left,right,Half way to hell......just put it in the hole.
THATS WHAT SHE SAID:p 2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
