Please advise: HK problem
buyitnow
Hi guys, been a long time.
So, my CD stopped playing, didn't even realize it at the time. Can't get anything to show or sound. TV says ' no signal or weak signal' in cable, vcr, and dvd mode. Radio stations don't come in. All displays look normal on receiver and react to remote control commands; but still no video or sound. Checked connections and everything seems o.k. I'm stymied. I turned everything off for a while then restarted, but nothing. Last option is to reset the processor on the HK. (update: did that and nothing improved)
I'm running everything through the receiver so it seems the receiver is acting funny. What do you guys think? Very frustrating fellas. Trouble shooting section in manual does not have solution to this scenario.
__________________
__________________
FONT="Tahoma"][/FONT]Room size: 18x14
RM6800
Harmon Kardon AVR235
56' Samsung DLP
RM6800
56' Samsung DLP
Post edited by buyitnow on
First, check all connections & check setttings on all equipment. If everything seems ok, then:
You need to isolate the faulty piece. Start by hooking your video, cable, etc. directly to the tv. If they work, then something is wrong with the receiver. Call HK...
Hope this helpsReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Did you try resetting the processor? Would try that first...everynow and then my 635 has a hiccup and a processor reset fixes it. Write down your settings first, as you will lose them upon a reset.Monitor Audio GR 60, GR10, GRLCR
Velodyne HGS18
Emotiva MMC-1
Parasound Model 5250
Denon DVD-3800
Pioneer pdp-5070
Secondary HT with B&W CDM-NTs all around and Rotel Separates (thanks Venom!)
