Please advise: HK problem
buyitnow
buyitnow Posts: 18
Hi guys, been a long time.
So, my CD stopped playing, didn't even realize it at the time. Can't get anything to show or sound. TV says ' no signal or weak signal' in cable, vcr, and dvd mode. Radio stations don't come in. All displays look normal on receiver and react to remote control commands; but still no video or sound. Checked connections and everything seems o.k. I'm stymied. I turned everything off for a while then restarted, but nothing. Last option is to reset the processor on the HK. (update: did that and nothing improved)
I'm running everything through the receiver so it seems the receiver is acting funny. What do you guys think? Very frustrating fellas. Trouble shooting section in manual does not have solution to this scenario.
__________________
FONT="Tahoma"][/FONT]Room size: 18x14
RM6800
Harmon Kardon AVR235
56' Samsung DLP
Post edited by buyitnow on
  • Mike682
    Mike682 Posts: 2,074
    edited June 2007
    First, check all connections & check setttings on all equipment. If everything seems ok, then:
    You need to isolate the faulty piece. Start by hooking your video, cable, etc. directly to the tv. If they work, then something is wrong with the receiver. Call HK...
    Hope this helps
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • scottdwagner
    scottdwagner Posts: 106
    edited June 2007
    Did you try resetting the processor? Would try that first...everynow and then my 635 has a hiccup and a processor reset fixes it. Write down your settings first, as you will lose them upon a reset.
    Monitor Audio GR 60, GR10, GRLCR
    Velodyne HGS18
    Emotiva MMC-1
    Parasound Model 5250
    Denon DVD-3800
    Pioneer pdp-5070
    Secondary HT with B&W CDM-NTs all around and Rotel Separates (thanks Venom!)
