Best multifunction remote?
Systems
What is the best multifunction remote out there that under $500? I still have my old Sony RM-AV3000 that just never worked right. When I say that I mean that I could get it working well after a full day of programming but it would eventually get wipped out. I need something good. I am an extreme techy so "complexity" does not scare me. I like that Logitech unit but Im reading a lot of bad reviews.
Specifically I would like to see a remote that can download from the internet my equipment at a high success rate (without custom programming ) for most the buttons working right.
Testing
Testing
Testing
Testing
Testing
The Harmony 1000 was dead simple. Logitech also has great support if you need it and you might. Being an "extreme techy" you should like the added functionality provided. So which Harmony had bad reviews?Michael
NORTH of 60° -
http://reviews.cnet.com/remote-controls/logitech-harmony-890/4852-7900_7-31630408.html?tag=uolstTesting
Testing
Testing -
Michael
NORTH of 60° -
Looks like almost all of the complaints are about the software? I find Logitechs software amazingly easy to use.
I needed a remote that was easy for the wife to use, and picked up the Harmony 520. Does everything I need, is the best universal remote I have ever bought, and suprisingly, it's also the cheapest.
I like it so much, I bought another one, just in case this one ever breaks. On sale at sears:
http://www.sears.com/sr/javasr/product.do?pid=05750015000&vertical=Sears&BV_UseBVCookie=Yes -
Universal Remotes MX850 or MX900 depending on which one you like better. Universal Remotes in my opnion are the most solid remotes made. They are so good man. I have programmed hundreds of them and they have such a high reliable factor. I have owned 3 of them and I have no desire to try anything else.
There is nothing better under 400.00Dan
How do you guys like the Harmony. The problem with my old Sony is that then you programmed your specific piece of equipment (say the receiver)... It only had 25% of the buttons. You could basically only do basic things on it without major programming. And even at that, button names and such didn’t match up. Say I want to switch around my output types on my receiver from THX to DTS to DD or such.Testing
Testing
Testing -
The Harmony 1000 functionality seems to be endless. I own a Proceed AVP-S and I have every command I need. Over 40. You can always customized other commands as well with the Learn IR functionality. Being an extreme techy you should enjoy this. One button does all.Michael
NORTH of 60° -
I really, really, really like my Harmony 1000. I have no problems recommending it to others.
I like the Harmony remotes too.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
I'm also in the market for a multi remote. Birthday in a week and nothing to ask for.....this should do.
Unfortunately, the woman would laugh if I asked for a 3-400$ remote, so I need to keep it a bit less pricey. Is the 880 the next best logitech? The 890's reviews didn't look near as good, and I've seen the 880 for around 100-120 (refurb.) Worth it?
Hope this is helps you too Silverti...2007 Club Polk Football Pool Champ
"It's like a koala bear crapped a rainbow in my brain!" -
hey, was just cruisin' for a bruisin' through egay for the harmony 1000 and found the seller that you bought yours from. i was researching the seller via their feedback when i saw that you left the seller your own feedback. sweet price.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
I have the 880 and it is a great remote. You wont have any problems with it.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
It was a good deal. Brand New. And that SOB has not left me feedback even after countless requests. That just pisses me off when people do that. Almost a month ago I purchased that.Michael
NORTH of 60° -
You request feedback? What are you buying on ebay, products or feedback? -
100-120? You are looking at brand new 550... I have 520, and love it!I'm also in the market for a multi remote. Birthday in a week and nothing to ask for.....this should do.
Hope this is helps you too Silverti...Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I have the product. When you buy something in a store does it mean anything to you when people say Thank You. That is commonly termed MANNERS. Somewhat uncommon today!Michael
NORTH of 60° -
I agree with that, but if they do not say thank you, I won't ask them to.
I just think you should be careful, as there are sellers that when repeatedly bothered for feedback, will leave it for you. But it won't be the feedback you want, especially if you have already left them a positive, and can't retaliate. -
Talk about subjective. Did you conduct any blind A/B tests? Do you have specs to prove what you claim or are we just suppose to take your word for it?Political Correctness'.........defined
President of Club Polk -
Your probably right, but I can withdraw the +FB.
And I once dated a female with a Master degree in Mathematics. I wonder if she would have trouble with the logic.Michael
NORTH of 60° -
Good god, I’m sitting here at my desk looking at literally 10 remotes on my desk:
I need one BAD.Testing
Testing
Testing -
Shelby/Janmike - I'm seriously thinking about the Harmony 1000 or 890....did you own a 880 or 890 prior? I may have the model numbers wrong, but the more traditional handhelds in other words.
Anyone else, feel free to comment, just noticed that they had a 1000.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Alright, I just bought a Harmony 1000 on ebay for $315 total. I watched Logitech’s little movie on it and it looks great. Cant wait to hide all these remotes. I already know that I’m going to have to keep one, my Play stations 3 Blue tooth remote. Pretty sure it’s not gonna work on the Harmony.Testing
Testing
Testing -
I swaped out my Pronto 3000 remote for the Harmony 880.
The pronto dose more but you need a Phd to program it. Tha Harmony is dead simple to use and program. The computer program makes it easy.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
Mark - The Harmony 1000 is the only universal remote that I have ever owned. It is dead simple to use, extremely versatile and will do more than I would ever want. Besides, it looks great.
The reason I selected the 1000 over the 880 and the 890 was my wife liked the look. Look at Logitech's web site to see the additional functionality that you may or may not use.Michael
NORTH of 60° -
Msalla - I agree on the Pronto comment. It was absolutely tedious to setup. I had a TSU5000 and just sold it, instead of trying to understand it. F it.
Jan - Ok, thanks. I definetly dig the look. What's the battery life on it for you?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
The remote that came with my NAD T773 receiver is all I'll ever need. Handles 8 devices, super easy to program & works like a charm. There's no need for me to even consider another remote. Now, if I ever sell the T773... well let's not worry about that just yet.
Not sure Mark. The longest I have ever left it out of the charger is one day and no problem. I did read on a forum that one guy had a day and after a firmware upgrade it was good for a week.Michael
NORTH of 60° -
My bro-in-law has the 880. Its the same as the 890, but the 890 has RF output ability. So, I saw his and used his before I bought the 1000. It essentially has the same functionality as the 880 and 890, but I believe with the RF output eventually its going to be able to control Zwave home automation products. -
I already know that Im going to have to keep one, my Play stations 3 Blue tooth remote. Pretty sure its not gonna work on the Harmony.
You are correct. -
Same here. It comes with a nifty cradle to store it on. I just put it on that every night. So, I know I can use it for at least two days straight without recharging it and it works fine.
