Best multifunction remote?
Systems
Systems Posts: 14,873
edited June 2007 in Electronics
What is the best multifunction remote out there that under $500? I still have my old Sony RM-AV3000 that just never worked right. When I say that I mean that I could get it working well after a full day of programming but it would eventually get wipped out. I need something good. I am an extreme techy so "complexity" does not scare me. I like that Logitech unit but Im reading a lot of bad reviews.
Specifically I would like to see a remote that can download from the internet my equipment at a high success rate (without custom programming ) for most the buttons working right.
Testing
Testing
Testing
  • janmike
    janmike Posts: 6,146
    edited June 2007
    The Harmony 1000 was dead simple. Logitech also has great support if you need it and you might. Being an "extreme techy" you should like the added functionality provided. So which Harmony had bad reviews?
    Michael ;)
    NORTH of 60°
  • Systems
    edited June 2007
    janmike wrote: »
    http://reviews.cnet.com/remote-controls/logitech-harmony-890/4852-7900_7-31630408.html?tag=uolst
    Testing
    Testing
    Testing
  • janmike
    edited June 2007
    Michael ;)
    NORTH of 60°
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited June 2007
    Looks like almost all of the complaints are about the software? I find Logitechs software amazingly easy to use.
    I needed a remote that was easy for the wife to use, and picked up the Harmony 520. Does everything I need, is the best universal remote I have ever bought, and suprisingly, it's also the cheapest.
    I like it so much, I bought another one, just in case this one ever breaks. On sale at sears:
    http://www.sears.com/sr/javasr/product.do?pid=05750015000&vertical=Sears&BV_UseBVCookie=Yes
  • mantis
    mantis Posts: 17,326
    edited June 2007
    Universal Remotes MX850 or MX900 depending on which one you like better. Universal Remotes in my opnion are the most solid remotes made. They are so good man. I have programmed hundreds of them and they have such a high reliable factor. I have owned 3 of them and I have no desire to try anything else.
    There is nothing better under 400.00
    Dan
  • Systems
    edited June 2007
    How do you guys like the Harmony. The problem with my old Sony is that then you programmed your specific piece of equipment (say the receiver)... It only had 25% of the buttons. You could basically only do basic things on it without major programming. And even at that, button names and such didn’t match up. Say I want to switch around my output types on my receiver from THX to DTS to DD or such.
    Testing
    Testing
    Testing
  • janmike
    edited June 2007
    The Harmony 1000 functionality seems to be endless. I own a Proceed AVP-S and I have every command I need. Over 40. You can always customized other commands as well with the Learn IR functionality. Being an extreme techy you should enjoy this. One button does all.
    Michael ;)
    NORTH of 60°
  • Shizelbs
    Shizelbs Posts: 7,433
    edited June 2007
    I really, really, really like my Harmony 1000. I have no problems recommending it to others.
  • Serendipity
    Serendipity Posts: 6,975
    edited June 2007
    I like the Harmony remotes too.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • jflail2
    jflail2 Posts: 2,868
    edited June 2007
    I'm also in the market for a multi remote. Birthday in a week and nothing to ask for.....this should do.
    Unfortunately, the woman would laugh if I asked for a 3-400$ remote, so I need to keep it a bit less pricey. Is the 880 the next best logitech? The 890's reviews didn't look near as good, and I've seen the 880 for around 100-120 (refurb.) Worth it?
    Hope this is helps you too Silverti...
  • BIZILL
    BIZILL Posts: 5,432
    edited June 2007
    janmike wrote: »
    hey, was just cruisin' for a bruisin' through egay for the harmony 1000 and found the seller that you bought yours from. i was researching the seller via their feedback when i saw that you left the seller your own feedback. sweet price. ;)
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Pepi28
    Pepi28 Posts: 248
    edited June 2007
    jflail2 wrote: »
    I have the 880 and it is a great remote. You wont have any problems with it.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
  • janmike
    edited June 2007
    BIZILL wrote: »
    It was a good deal. Brand New. And that SOB has not left me feedback even after countless requests. That just pisses me off when people do that. Almost a month ago I purchased that.
    Michael ;)
    NORTH of 60°
  • WilliamM2
    edited June 2007
    You request feedback? What are you buying on ebay, products or feedback?
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2007
    100-120? You are looking at brand new 550... I have 520, and love it!
    jflail2 wrote: »
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • janmike
    edited June 2007
    WilliamM2 wrote: »
    I have the product. When you buy something in a store does it mean anything to you when people say Thank You. That is commonly termed MANNERS. Somewhat uncommon today!
    Michael ;)
    NORTH of 60°
  • WilliamM2
    edited June 2007
    I agree with that, but if they do not say thank you, I won't ask them to.
    I just think you should be careful, as there are sellers that when repeatedly bothered for feedback, will leave it for you. But it won't be the feedback you want, especially if you have already left them a positive, and can't retaliate.
    F1nut Posts: 51,703
    edited June 2007
    WilliamM2 wrote: »
    Talk about subjective. Did you conduct any blind A/B tests? Do you have specs to prove what you claim or are we just suppose to take your word for it?
  • janmike
    edited June 2007
    WilliamM2 wrote: »
    Your probably right, but I can withdraw the +FB.
    And I once dated a female with a Master degree in Mathematics. I wonder if she would have trouble with the logic.
    Michael ;)
    NORTH of 60°
  • Systems
    edited June 2007
    Good god, I’m sitting here at my desk looking at literally 10 remotes on my desk:
    I need one BAD.
    Testing
    Testing
    Testing
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2007
    Shelby/Janmike - I'm seriously thinking about the Harmony 1000 or 890....did you own a 880 or 890 prior? I may have the model numbers wrong, but the more traditional handhelds in other words.
    Anyone else, feel free to comment, just noticed that they had a 1000.
  • Systems
    edited June 2007
    Alright, I just bought a Harmony 1000 on ebay for $315 total. I watched Logitech’s little movie on it and it looks great. Cant wait to hide all these remotes. I already know that I’m going to have to keep one, my Play stations 3 Blue tooth remote. Pretty sure it’s not gonna work on the Harmony.
    Testing
    Testing
    Testing
  • MSALLA
    MSALLA Posts: 1,602
    edited June 2007
    I swaped out my Pronto 3000 remote for the Harmony 880.
    The pronto dose more but you need a Phd to program it. Tha Harmony is dead simple to use and program. The computer program makes it easy.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • janmike
    edited June 2007
    Mark - The Harmony 1000 is the only universal remote that I have ever owned. It is dead simple to use, extremely versatile and will do more than I would ever want. Besides, it looks great.
    The reason I selected the 1000 over the 880 and the 890 was my wife liked the look. Look at Logitech's web site to see the additional functionality that you may or may not use.
    Michael ;)
    NORTH of 60°
  • dorokusai
    edited June 2007
    Msalla - I agree on the Pronto comment. It was absolutely tedious to setup. I had a TSU5000 and just sold it, instead of trying to understand it. F it.
    Jan - Ok, thanks. I definetly dig the look. What's the battery life on it for you?
  • pearsall001
    pearsall001 Posts: 5,249
    edited June 2007
    The remote that came with my NAD T773 receiver is all I'll ever need. Handles 8 devices, super easy to program & works like a charm. There's no need for me to even consider another remote. Now, if I ever sell the T773... well let's not worry about that just yet.
  • janmike
    edited June 2007
    dorokusai wrote: »
    Not sure Mark. The longest I have ever left it out of the charger is one day and no problem. I did read on a forum that one guy had a day and after a firmware upgrade it was good for a week.
    Michael ;)
    NORTH of 60°
  • Shizelbs
    edited June 2007
    dorokusai wrote: »
    My bro-in-law has the 880. Its the same as the 890, but the 890 has RF output ability. So, I saw his and used his before I bought the 1000. It essentially has the same functionality as the 880 and 890, but I believe with the RF output eventually its going to be able to control Zwave home automation products.
  • Shizelbs
    edited June 2007
    Silverti wrote: »
    You are correct.
  • Shizelbs
    edited June 2007
    janmike wrote: »
    Same here. It comes with a nifty cradle to store it on. I just put it on that every night. So, I know I can use it for at least two days straight without recharging it and it works fine.
